Jimny 2007 - transmission cooler for an automatic transmission
  • adirsabag
09 Jun 2019 20:09 #209779 by adirsabag
hello, I am new here, nice to meet you all. I'm owning a 2007 Jimny, M13A VVT, automatic.
I have been looking for a tranny cooler, and got my eyes on two types: tube and fin, plate and fin.
A jimny mechanic told me that the jimny tranny is so sensitive that it demands the tube and fin, even that the plate and fin is actually better at heat reduction, because of better oil flow.
Is is true that I need the tube and fin cooler?
Thank you.
09 Jun 2019 20:24 #209783 by Keithy
adirsabag wrote: hello, I am new here, nice to meet you all. I'm owning a 2007 Jimny, M13A VVT, automatic.
Thank you.
If it demands the tube and fin.....but the plate and fin is more efficient at dissipating heat.......then you have a decision to make.........give in to the demands or go with the most efficient design.
No brainer really.....No?
  • adirsabag
09 Jun 2019 20:36 #209784 by adirsabag
I'm asking what to do. I got it that the plate and fin is more efficient at heat reduction, but is it really that bad at oil flow that the mechanic had to say that i better get the tube and fin?
09 Jun 2019 21:51 #209785 by Keithy
adirsabag wrote: I'm asking what to do. I got it that the plate and fin is more efficient at heat reduction, but is it really that bad at oil flow that the mechanic had to say that i better get the tube and fin?
The single tube is the simplest to mount or install.....I've seen a nice one from Mishimoto with a fan.
Mishimoto Cooler Here
Stacked plate would be my choice......but bear in mind I have a left leg and a manual gearbox.
  • adirsabag
09 Jun 2019 23:26 #209786 by adirsabag
Keithy wrote: The single tube is the simplest to mount or install.....I've seen a nice one from Mishimoto with a fan.
ok, thank you!
10 Jun 2019 04:07 #209790 by Lambert
I have also been doing a bit of research on this as I may have to eventually use an automatic for towing. I too was looking at the heavy duty fan assisted one Keith linked to above. It claims to be able to offer a 34 degree reduction in oil temperature. It also looks quite simple to install.
Time to create page: 0.294 seconds
