Jimny Spotlights
- Dorbs
05 May 2019 20:31 #207412
by Dorbs
Jimny Spotlights was created by Dorbs
Hi
Can someone explain how to wire in spotlights that are connected to high beam and have an additional isolator switch in the cab.
Any help would be great !
Lots of people have various ways/ideas but the information seems disjointed and incomplete in many cases.
Maybe a simple drawing would help many people
Thank you in advance
Dorbs
Dorbs
- Thank you received: 227
06 May 2019 09:08 #207437
by zukebob
Replied by zukebob on topic Jimny Spotlights
06 May 2019 09:15 #207438
by zukebob
Sorry. Forgot to label the relay pins.
The lead to battery positive with inline fuse would be pin 30
Relay lead to ground would be pin 85
Relay lead to Spot would be pin 87
The lead from the red wire, through the override switch would connect to pin 86
All of this assumes a wiring harness with relays and inline fuses was supplied with the spots.
- Dorbs
06 May 2019 10:56 #207448
by Dorbs
Replied by Dorbs on topic Jimny Spotlights
Thank you very much, I really appreciate it, have a good day !
07 May 2019 01:16 - 07 May 2019 01:20 #207471
by zukebob
I would normally say "glad I could help" but actually hope you haven't done this yet and see this new post. I've done a decent amount of electrical on the Jimny but too often go back to the grounding system concept of my previous vehicles during discussions.
A corrected diagram is this:
Hopefully this hasn't created any problems.
Last edit: 07 May 2019 01:20 by zukebob.
- Dorbs
07 May 2019 19:18 #207497
by Dorbs
No worries! Just appreciate your help!
Thanks again
Thanks again
Time to create page: 0.114 seconds
