Steering boxes
- Mole
06 Mar 2019 18:56 #204201
by Mole
Steering boxes was created by Mole
As titled I can't get rid of the play In the steering box so have decided to replace it my question is are they all the same or do the differ with different jimny models?
Thanks
Thanks
06 Mar 2019 19:00 #204202
by sniper
Replied by sniper on topic Steering boxes
I think they are the same across the range, I have seen a guy offering rebuilt units on Ebay, £170ish if my memory serves.....
sniper
sniper
- Mole
06 Mar 2019 19:10 - 06 Mar 2019 19:11 #204203
by Mole
Replied by Mole on topic Steering boxes
Yeah that's about right I have toyed with just a second hand one there is a 2010 one for £50 mine is a 2002. iv adjusted mine right up but is just tight with play
Last edit: 06 Mar 2019 19:11 by Mole.
- Thank you received: 2004
06 Mar 2019 19:55 #204207
Replied by Lambert on topic Steering boxes
As far as I am aware the only difference is between power and none power steering but both types are the same throughout the gen3 models.
The following user(s) said Thank You: Mole
07 Mar 2019 06:26 #204226
by kirkynut
Replied by kirkynut on topic Steering boxes
Have you tried to adjust it properly? When I did mine I overtightened it to start with and had to back it off. So I doubt you need a new box. There will always be some play as is the nature of steering boxes.
07 Mar 2019 06:48 #204228
Replied by yakuza on topic Steering boxes
Is the box servicable?
Original parts available?
My experience with these is that when you start to adjust it will not get better. my car has 112000km on it and i do not like the play in the box. have had to tighten it two times, first at around 95000km and last time at 105000km.
Think it was the same on the SJ and after a couple of tightenings it gets tight at full left/right when it you have removed the play at straight.
Gets worse faster with bigger tires and wobble of course.
When changing the steering box for my SJ I thought i'd pop the lid on the ones I had in stock and look at the inside. I think there was rusty water inside 3 of 5 boxes. This is better with the servo assisted ones as the hot oil from the pump and reservoir will evaporate any condensation.
Time to create page: 0.099 seconds
