G16B 1999+ Baleno engine in a 1999 Jimny
- Thank you received: 462
27 Feb 2019 08:31 - 06 Mar 2019 06:18 #203880
G16B 1999+ Baleno engine in a 1999 Jimny was created by yakuza
Helping a local guy to do this swap. I am having a hard time finding a how to and info on here that is more or less complete.
If someone is better at searching please link here.
have to do:
- adapter on the gearbox (my own design)
- oil pickup fix -weld job using the G13BB pipe with the G16 top end and flange.
- engine mount fix (right side is ok?) -weld job moving the mount 2.5cm on the g16
- bolts trickery as i have not sourced the outer ones at bottom gearbox flange. -weld or inserts or lathe job.
- reuse G13BB generator and pump brackets
- reuse G13BB water pipes
- reuse G13BB intake and exhaust manifold.
- use G16B injectors
- reuse G13BB engine wiring loom and ECU.
- doing the clutch and belts.
- removing oil filter angle mount, [strike]using original Suzuki stud.[/strike]
- Reuse the stud from the G13BB as the m13a stud is too short for the G16B.
blank off the crank sensor at the oil pan?
I thought that we did not have to swap the cam, correct?
anything else?
have to do:
anything else?
Last edit: 06 Mar 2019 06:18 by yakuza. Reason: add info
- MadsV
27 Feb 2019 17:26 #203892
by MadsV
Replied by MadsV on topic G16B 1999+ Baleno engine in a 1999 Jimny
Its pretty detailed with pics in my thread. The cam can be used, check the amount of lugs on the trigger wheel/ring at the end. I swapped mine over from the 1,3 cam. Its all good if you set both engines at TDC and mark the ring.
I have also done this before with putting the 1,3 cam in the g16 head, no problem
- Rabid Rhino
- Elite Member
- Thank you received: 33
05 Mar 2019 18:51 #204150
by Rabid Rhino
Replied by Rabid Rhino on topic G16B 1999+ Baleno engine in a 1999 Jimny
It would be nice to se a summarized thread of just the engine install here as you do it with help from MadsV thread & a link to it with the page numbers for a reference.
06 Mar 2019 06:19 - 06 Mar 2019 06:24 #204164
Replied by yakuza on topic G16B 1999+ Baleno engine in a 1999 Jimny
Adding info and correcting the first post as I check things. will take some time this as the service parts come and we get the time to do the work.
www.bigjimny.com/index.php/forum/8-my-ji...r-norwegian?start=96
there is MadsV's good pictures in his thread.
Last edit: 06 Mar 2019 06:24 by yakuza.
08 Mar 2019 14:29 #204310
by Bosanek
Replied by Bosanek on topic G16B 1999+ Baleno engine in a 1999 Jimny
It would be great if those who have done it would write a guide in
this wiki article
- MadsV
10 Mar 2019 07:27 #204374
by MadsV
I will see if I can make a wiki about it sometime. If anyone else wants to feel free to use my photos
Time to create page: 0.160 seconds
