Re:SZ4/SZ5 possible upgrades discussion.
  • mikeyw85
27 Jan 2019 18:26 #201866 by mikeyw85
Replied by mikeyw85 on topic Re:SZ4/SZ5 possible upgrades discussion.
reedx wrote:
Gadget wrote: I'm really close to pulling the trigger on a set of BF Goodrich A/T tyres in 215/75R15 on the stock alloys. Was disappointed to find that the stock Bridgestone Duellers are only the HT and not AT version, so no 3peaks or M+S marking.
Are the stock alloys wider than the standard steel wheels? From what I've read 195 is the maximum width on the 5.5" steel rim.
Colin
On a lower profile car tyre I’d say the 5.5 steel rim in too narrow for a 215 tyres. However, on a higher profile tyre I think it’s no issue. I found some info to back this up somewhere...
27 Jan 2019 20:10 - 27 Jan 2019 20:11 #201880 by Soeley
Gadget wrote: Duplicating a lot of this convo in the 2019 Jimny Facebook group and thanks to others have come to realise that the stock Dueler H/T tyres are M+S (if not 3PMSF) marked, so likely to be fine for 99% of my needs. Only reason to go bigger would be for aesthetic reasons.
I'm still trawling the accessory catalogues and would really like to get some of the luggage hooks (9915F-78R00-000), but sadly not listed as a UK accessory yet. Pricing is bizarren though, on the Swiss Suzuki site they've got them listed for £138, for 4 little D-ring things! :ohmy:
Which hooks are those the ones shown for under the rear side windows or the ones at the bottom of the rear door opening?
On Friday I left some part numbers with my dealer to find out if they could get them (that was before Martin put up his post). I will see if they get back to me this week. Alternatively I have these as back-up or
Last edit: 27 Jan 2019 20:11 by Soeley.
  • cyberdriver
28 Jan 2019 02:19 #201892 by cyberdriver
Replied by cyberdriver on topic SZ4/SZ5 possible upgrades discussion.
I'd like to keep mine in stealth mode - relatively modest tyres and no lift. I will want all terrain tyres though, and 215/75R15 seems like a decent upgrade as you can stick with the original alloy rims. Those BFG's are heavy though - the extra rotational weight must be sapping performance and sucking fuel, not to mention eating into the limited GVM. A set of Toyos is 30 lbs lighter: tiresize.com/tires/Toyo/Open-Country-AT-II-215-75R15.htm . Seems like a winner!
28 Jan 2019 06:13 #201894 by Gadget
Soeley wrote: Which hooks are those the ones shown for under the rear side windows or the ones at the bottom of the rear door opening?
It's the ones at the bottom of the rear door. Thanks for the links, will be nterested to hear what your dealer says.
28 Jan 2019 12:18 #201913 by Soeley
I have seen plenty like the ones you mean, but they don't have the little bent tab to stop them twisting around the bolt hole. I'll keep you posted.
The following user(s) said Thank You: Gadget
28 Jan 2019 14:17 #201919 by saxj
Colin
The wheels are exactly the same dimensions as all previous Jimny's. 215's are fine on 5.5J rims. We have gone up to 31" tyres with no problems with the rims.
Time to create page: 0.384 seconds
