4wd on the move
  • Cremator1
07 Jan 2019 18:38 #200132 by Cremator1
4wd on the move was created by Cremator1
Hi all ok so got an auto I am getting a bit worried about using the 4wd on it used it on the farm fields track ok .but I I am worried when the snow comes live on a lane so no snowploughs go up it so yes I no I can put it in 4wd but do I have to keep stopping to take it out of 4wd when road I’d clear of snow and then stop again to put it back in 4wd when I come across now on the road hope makes sense any advice would be great before the snow comes. On the farm I just put it in 4wd and leave it many thanks dawn
07 Jan 2019 18:46 #200134 by adrianr
Replied by adrianr on topic 4wd on the move
You can put it into 4wd at up to 60mph on a straight road, and take it out again - there should be instructions on the sun visor. Makes it really simple.
07 Jan 2019 18:50 #200135 by Riccy
Replied by Riccy on topic 4wd on the move
Jimnys dont have a central diff, which means the transfer box can be damaged by continued driving on grippy surfaces in 4x4. Short distances on and off tarmac are ok in 4x4, but dont leave it there.
You need to take it out of 4x4 but its not necessary to stop to do that (between 4 high and 2 high). You only need to stop if its in 4 Low. I believe you can change from 2 to 4 high box (or vice versa) at up to 60mph, certainly easy enough at low speeds.
This does mean you need to be careful in 2wd of black ice, so you really cant go any faster or stop any better than an ordinary car on that sort of mixed surface.
  • Cremator1
07 Jan 2019 18:51 #200136 by Cremator1
Replied by Cremator1 on topic 4wd on the move
Yes I have read on here about it but is it really ok to do it also mine is auto and to put it in 4wd while it’s still u have to put it in neutral and foot on the brake
07 Jan 2019 18:55 #200137 by Riccy
do you have a stick shifter for the transfer box, or buttons on the dashboard. Im not familiar with auto's. Lambert will be along shortly and he will know...
  • Cremator1
07 Jan 2019 18:56 #200138 by Cremator1
Hi Riccy I have the buttons on mine x
Time to create page: 0.226 seconds
