where is that vacuum tank
  • olboa
15 Sep 2018 21:57 #196015 by olboa
where is that vacuum tank was created by olboa
Hey everyone new to the jimny forum
my daughter has and loves her jimny and gets dad to fix it
She recently complained about an intermittent whistle coming from the front left area
I threw it up onto my hoist and found that there is no front hub locking happening
mmmm could the whistle be a vacuum leak?
A quick check and all of the lines look OK but I cannot find the vacuum tank, hence this post.
Cab someone point me in the right direction to this little tank
Thanks
Olboa
15 Sep 2018 22:33 - 15 Sep 2018 22:34 #196017 by facade
Replied by facade on topic where is that vacuum tank
It is under the drivers wing, above the plastic splash guard.
I think the end of it comes out into the engine compartment anyway.
The tube from the manifold runs to the 2 solenoid valves via a non return valve and is teed to the vacuum tank.
The solenoid valves are change over ones, they either vent the hub lines to atmosphere via a little foam filter, or connect either hub line to the vacuum tank. This only happens for a few seconds each time 4wd is activated or dis-engaged.
The solenoid valves have a tendency to stick and not change over fully, so the vacuum line just connects to atmosphere and no vacuum happens in the tank.
Last edit: 15 Sep 2018 22:34 by facade.
Time to create page: 0.196 seconds
