M13a engine light and misfire.
05 Sep 2018 17:42 #195716
Replied by Riccy on topic M13a engine light and misfire.
have a look at helicoils, that might be the solution you need there
The following user(s) said Thank You: walesy
- mickt
05 Sep 2018 18:51 #195717
by mickt
Replied by mickt on topic M13a engine light and misfire.
You can get spark plug thread chasers which might do the trick. They are double ended for the two thread sizes normally used. Ebay or if you are near Halfords or Machine Mart (£5.99 CHT261 That price was last years so it might be more now) Worth a try. If he had not torque loaded them then they probably worked loose, except of course the cross threaded one! Ali heads need to be treated with care and torque loading all fittings is essential.
- walesy
05 Sep 2018 19:13 #195718
by walesy
[/Will try the thread chaser first the if that doesn't work l'll give the helicoil a go. Thanks. sup]
Replied by walesy on topic M13a engine light and misfire.
Code:
06 Sep 2018 09:36 #195729
Replied by yakuza on topic M13a engine light and misfire.
For aluminium threading, use Denatured alcohol on the tap so the threads gets smoother. Cuts better with etanol for some reason.
Not sure how to, but it could help to put air pressure inside the cylinder to blow out debris from cutting..
If it was steel cutting you could put grease on the tap and hope the debris got stuck on it..
And helicoils are not my favourite. They often leak as well you will need some thread locking and sealing compound on them.
- walesy
10 Sep 2018 18:46 #195849
by walesy
looking at the heli coil type repair it looks like you have to snap off a tab using long nose pliers which won't work with the head on the engine. There is a a german v coil system which doesn't have a tab. any one used one of these?
I'm also wondering how difficult it would be to remove and replace the head myself. it's mainly the engine timing i'm worried about.
- mickt
10 Sep 2018 19:01 #195851
by mickt
Have you worked on engines before or/and do you know the basics of how an engine works? The crankshaft rotates twice to the camshafts once is the important thing to know. Timing is straight forward as long as you align the camshafts and crankshaft correctly so with the crankshaft at top dead centre i.e piston no I ( one at front of the engine) at the top of its bore and the valves of that cylinder closed will be the datum point for removal and refit. But try the thread chaser first. They do work with care. Getting it started in the right place is the key. The head being aluminium and the chaser steel can lead to a false thread being cut.
Time to create page: 0.198 seconds
