Which roof rack for Jimny?
  • Niro
18 Apr 2018 08:21 #191851 by Niro
Which roof rack for Jimny? was created by Niro
Hello everybody,
I want to install stable roof racks on my Jimny, because lately I like to go kayaking and somehow have to transport it to the lake and back. These ones look stable: www.sortimo.co.uk/products/topsystem/ What do you think? Would you put that into your Jimnys?
Thank's for the Tipps.
  • Daniel30
18 Apr 2018 09:29 - 18 Apr 2018 09:34 #191853 by Daniel30
Replied by Daniel30 on topic Which roof rack for Jimny?
if you need something stable you really need to get a roof rack that uses the original mounting points on the roof that the plastic roof bars are mounted to, maybe find someone around your area that can fabricate some brackets and bars i shouldn't think someone in the know how would take long making them up, i have a land rover roof rack with custom brackets and its solid.
Last edit: 18 Apr 2018 09:34 by Daniel30.
  • mdog18
18 Apr 2018 10:05 #191856 by mdog18
Replied by mdog18 on topic Which roof rack for Jimny?
I would agree with Daniel, however, when I was looking for roof racks I was deterred by the prices and ended up going for this one I found on Amazon: www.amazon.co.uk/gp/product/B073HBFKD1/r...05_s00?ie=UTF8&psc=1
It was the lowest price I could find and after 3 months using it I have to say I have no complaints. Very solid, very reliable, easy to install because you dont have to damage your roof with screws or bolts :)
It comes with roof rails included so the price is really 2 for 1.
  • Daniel30
18 Apr 2018 13:33 - 18 Apr 2018 13:35 #191862 by Daniel30
i used the original studs that are left behind and a piece of rubber under the brackets so there is no damage, depends how much weight you need to carry Niro?
As mdog18 has mention that link is an easier solution and someone has tried and tested it :)
Last edit: 18 Apr 2018 13:35 by Daniel30.
  • Venter
18 Apr 2018 14:16 #191863 by Venter
Replied by Venter on topic Which roof rack for Jimny?
mdog18 wrote: I would agree with Daniel, however, when I was looking for roof racks I was deterred by the prices and ended up going for this one I found on Amazon: www.amazon.co.uk/gp/product/B073HBFKD1/r...05_s00?ie=UTF8&psc=1
The Amazon page says that it comes with the roof basket and the roof bars, not the rails, so I just want to check that I'm reading it correctly...
Just for clarity, bars go across, and rails are in line with the car's direction of travel.
The reason I'm asking is that the stock Jimny rails are a known weak point, so if it comes with bars, these will still attach to the flimsy rails.
As mentioned by Daniel30, the most reliable way of doing things is to remove the stock rails altogether, and then get a rack that screws into the same fixing points that the rails were previously mounted to.
  • X8GGY
18 Apr 2018 14:25 #191864 by X8GGY
Replied by X8GGY on topic Which roof rack for Jimny?
No eBay APP ID and/or Cert ID defined in Kunena configurationI got one of these -
Time to create page: 0.662 seconds
