driving in 4wd Hi
  • JonathonMarshall
22 Nov 2010 22:11 #6329 by JonathonMarshall
driving in 4wd Hi was created by JonathonMarshall
With the onset of snow seeming immenient I was wondering at what stage transmission windup would be an issue when running in High Ratio 4wd. Can I use it more of a preventative measure rather than one i start losing traction however slight?
  • 4wheelers
22 Nov 2010 22:22 #6330 by 4wheelers
Replied by 4wheelers on topic Re: driving in 4wd Hi
Not a good idea to use 4wd on tarmac unless the tarmac is actualy covered in slippery snow/ice.
  • JonathonMarshall
22 Nov 2010 22:33 - 22 Nov 2010 22:34 #6331 by JonathonMarshall
Replied by JonathonMarshall on topic Re: driving in 4wd Hi
I did think as much, as will diff lock on LR's. I'm just thinking of how tail happy a Rwd jimny is going to be! Plenty weight in the back'd be a plan i think!....then i notice your pic, what is it like on snow and ice mate? Both in 2 and 4
Last edit: 22 Nov 2010 22:34 by JonathonMarshall.
  • 4wheelers
23 Nov 2010 00:12 #6332 by 4wheelers
Can be quite easy to spin on ice in 2wd but if you play it safe and drive to the conditions it is fine. My rule of thumb is once I start to slide apply 4x4 and then keep on taking things easy. you will have twice as much grip as regular cars in forward motion. The thing is though pulling up is the same as any other car. So lots of space in front is still a good idea.
  • adamjimny
23 Nov 2010 06:33 #6333 by adamjimny
Replied by adamjimny on topic Re: driving in 4wd Hi
4wheelers wrote: Can be quite easy to spin on ice in 2wd but if you play it safe and drive to the conditions it is fine. My rule of thumb is once I start to slide apply 4x4 and then keep on taking things easy. you will have twice as much grip as regular cars in forward motion. The thing is though pulling up is the same as any other car. So lots of space in front is still a good idea.
exactly what i do but some idiot think 4x4's are amazing and dont slide ie doing silly speeds still then wonder why they crash. keep enough room in front
  • mcjimny
23 Nov 2010 08:41 #6335 by mcjimny
Replied by mcjimny on topic Re: driving in 4wd Hi
Where the snow is patchy i drive with care in 2wd, most of the roads i drove on last year were entirely snow covered though so 4 high was fine. The dual carriageways were untouched in the outside lane so i knocked into 4hi and had a lane to myself. It drove better in a good layer of snow in 4wd to be honest than on the patchy bits in 2wd. Once it froze i was in 4lo on some roads where you were reduced to a crawl, the engine braking was useful.
Time to create page: 0.166 seconds
