Front fog lamp alternatives (LED bars, etc.)
16 Mar 2018 07:37 - 16 Mar 2018 07:39 #190488
by Bosanek
Front fog lamp alternatives (LED bars, etc.) was created by Bosanek
I got really fed up with the large 2nd generation front bumper (2006-2012). So I obtained the much smaller 1st generation front bumper (1998-2005) to swap over.
However, the specific situation with my 63 kW diesel Jimny is that the mounting position of the right front fog lamp, if used in the 1st generation front bumper, would collide with the intercooler which is positioned there.
Therefore, I would not be able to use the right front fog lamp if I mounted the smaller front bumper.
And I do not want to abandon fog lamps, because I live in the region which usually experiences dense fogs and smogs for up to half a year (October - April).
This is the front bumper model which I want to install:
So, does anyone have an alternative idea what to do?
Are there some much shallower fog lamps to put in the fog lamp holes?
What about some small horizontal LED bars to mount somewhere on / in that front bumper, to function as fog lamps? How to LED perform in fog anyway?
Last edit: 16 Mar 2018 07:39 by Bosanek. Reason: Link correction
- Thank you received: 227
16 Mar 2018 07:52 #190489
by zukebob
Replied by zukebob on topic Front fog lamp alternatives (LED bars, etc.)
Can't answer the first part of your post but LEDs work well in fog.
Here is a link with some info:
LED fog lights
LED fog lights
- Herzog
16 Mar 2018 09:24 #190494
by Herzog
Replied by Herzog on topic Front fog lamp alternatives (LED bars, etc.)
I have an LED light bar mounted across the roof rack on mine.
Works great for off-roading and doesn’t interfere with the front fog lights.
Just an idea.
Just an idea.
- jamie_300
16 Mar 2018 17:32 #190507
by jamie_300
Replied by jamie_300 on topic Front fog lamp alternatives (LED bars, etc.)
I have LED Fog Lights mounted in front of the radiator grill, bought the mounts from eBay, and the fog lights from a local Land Rover specialist. Work extremely
- rappey
16 Mar 2018 19:28 #190516
by rappey
Replied by rappey on topic Front fog lamp alternatives (LED bars, etc.)
Mounted that high they are driving lights, not fog lights.. Fog lights need to be as low as possible to cut under the mist and reduce reflection from the water droplets.
Led,s are often daylight white (6000k) whereas fog lights using incandescent lamps are around 3400k, giving a muchmore yellow light and reduce the glare the driver gets.
I have xenons in my everyday car and in fog they reflect off the mist something terrible! I'm sure oncoming cars can see me clearly though.
