gear change
10 Nov 2017 21:59 #186065 by Roy
gear change was created by Roy
Anyone experience notchy gearchanges my Jimny is not very smooth through the gears clutch seems ok no slip or drag so was wondering if its a standard thing are these cable or direct into box it just seems to baulk through changes clutch slave maybe?.
  • kelly7777
11 Nov 2017 05:10 #186072 by kelly7777
Replied by kelly7777 on topic gear change
Hi Roy
It will have a clutch cable. Replacing the gearbox oil with fully synthetic helped with a gearbox problem I had, replacing the clutch cable was cheap and that helped too.
I used comma fully synthetic GL4 MVMTF 75W 90 from Halfords
11 Nov 2017 09:59 #186075 by Roy
Replied by Roy on topic gear change
Ho thanks for that will do the Japs normally do a good gearbox so a bit irritating but hey its still the best little 4x4.on the market.
  • rappey
11 Nov 2017 19:22 #186085 by rappey
Replied by rappey on topic gear change
by all accounts from motoring magazines/programs that have reviewed the jimny the gearchange is not that great and neither is the road driving, compared to other new cars, but what it can do off road more than makes up for it...
12 Nov 2017 04:53 #186103 by Lambert
Replied by Lambert on topic gear change
Changing the gearbox oil is a good idea but be cognisant of the need to use gl4 oil. Some factors will insist that they have a gl4/5 super clever oil that is suitable. It is not. I had some in my black one for a.short time and once warm it was impossible to get out of 5th and the rest weren't particularly easy to find either. I swapped to a proper gl4 and it has been fine for the last few years. Prolonged use of gl5 is not good for the yellow metal in the gearbox and will cause shortened lifespans.
  • Mraz
12 Nov 2017 10:12 #186114 by Mraz
Replied by Mraz on topic gear change
I've just changed all my oils including gearbox one and shifting has definitely improved and now goes into second gear a lot easier than before.
Time to create page: 0.187 seconds
