RPM drop on electric load
  • ggregorsch
05 Oct 2017 08:27 - 05 Oct 2017 08:31 #184865 by ggregorsch
RPM drop on electric load was created by ggregorsch
Hello friends,
New member here.
My car: Jimny 2001 Japan made.
My problem:
With engine at idle, when depressing brake pedal (brake lights on) or when lifting both windows in the same time, the RPM drops from approx 800 rpm at idle at about 350-400 RPM and the car shakes a bit, like trying to stall. The issue is more persistent in cold weather.
I have cleaned the ground points (engine bay and car interior) but still have this problem.
Any suggestions are welcomed.
Thanks in advance!
I'm sorry for posting in the wrong section, maybe the admin will move it to Jimny technical. Thanks!
Last edit: 05 Oct 2017 08:31 by ggregorsch.
05 Oct 2017 08:37 #184868 by Busta
Replied by Busta on topic RPM drop on electric load
Clean the idle control valve, check the crankcase pressure valve is working and replace if necessary.
  • ggregorsch
05 Oct 2017 11:35 - 05 Oct 2017 11:36 #184876 by ggregorsch
Replied by ggregorsch on topic RPM drop on electric load
I forgot to mention but I have cleaned the IAC valve an the PCV valve is brand new (and working).
I've checked the alternator on professional tester and it is in good condition. Battery is brand new.
I am a former Suzuki Samurai user (drove it for almost 8 years) and I'm familiar somewhat with these engines.
It seems that ECU doesn't detect the applied electric load and doesn't increase engine RPM accordingly.
If I use the headlights (even on strong beam), RPM increases for a moment, then drops to normal idle.
Thanks!
Last edit: 05 Oct 2017 11:36 by ggregorsch.
05 Oct 2017 12:36 #184879 by Rhinoman
Replied by Rhinoman on topic RPM drop on electric load
The ECU should detect electrical load, you need to check the inputs to the ECU.
  • ggregorsch
05 Oct 2017 17:23 #184883 by ggregorsch
Replied by ggregorsch on topic Re:RE: RPM drop on electric load
Rhinoman wrote: The ECU should detect electrical load, you need to check the inputs to the ECU.
The ECU detects electric loads (headlights, heater fan). RPM drops only when applying brakes or when I lower or close both windows in the same time.
Maybe I have missed a ground spot. Are there any ground connections under the rear bumper or around tail lights?
Thank you!
Sent from my Redmi Note 4 using Tapatalk
05 Oct 2017 21:28 #184887 by Busta
The brakes use the engine's vacuum so pressing then will normally cause the idle to fluctuate.
Time to create page: 0.222 seconds
