Re:Re:Grand vitara calipers and discs
  • Nissan300
  • Visitor
  • Visitor
03 Jun 2017 18:20 #181728 by Nissan300
Grand vitara calipers and discs was created by Nissan300
Hi guys I know no vitara calipers and disc are a direct replacement anbd upgrade to the jimny solid front discs my question is will grand vitara discs and calipers also bolt straight on ?.
Sent from my SM-G935F using Tapatalk
03 Jun 2017 19:30 #181731 by Keithy
I have vitara calipers and jimny vented discs fitted....fitted straight in....I remember bleeding was a modified approach as the nipple was lower....but they fitted straight on.
  • Nissan300
  • Visitor
  • Visitor
04 Jun 2017 07:18 #181738 by Nissan300
Replied by Nissan300 on topic Re:Grand vitara calipers and discs
So just to confirm your calipers came off a grand vitara 98 on not the early vitara ?.
04 Jun 2017 07:59 #181742 by Keithy
I think mine are the early vitara.....caliper itself is the same as grand vitara....not measured the carriers though. mdb1690 pads
  • Nissan300
  • Visitor
  • Visitor
04 Jun 2017 13:30 #181755 by Nissan300
Thanks Keithy it's been hard trying to find early vitara calipers that had vented discs and a 5 door for bigger pistons.
06 Jun 2017 07:24 #181780 by yakuza
These calipers are readily available new, and not so costly either if you buy them online.
I strongly recommend to buy spanking new brake parts mainly for two reasons:
Availability. If we don't buy new service parts they will be more expencive due to lesser volume made and in the worst case discontinued.
Safety. I sell alot of used car parts but never sell used brake parts or other safety related parts like seat belts..
You never know what the donor vehicle has been thru.
Early Vitara lwb 5 door 1.6 16v calipers from around beginning to 1998 will fit.
Note that 3 door and 8 valve models does not have vented discs.
Bleed port will not face upwards so you will need to loosen calipers and turn so the bleed vent is up when you bleed the brakes as Keithy mentioned .
Early Vitara vented discs has smaller inner diameter in the center hole on the brake disc so these did not fit my 2005 Jimny.
But Jimny Diesel discs is the thing i guess?
06 Jun 2017 10:07 #181782 by Lambert
Forgive my ignorance but do you also need the carrier from the donor or is it just the new caliper that bolts to the existing Jimny carrier?
  • Nissan300
  • Visitor
  • Visitor
06 Jun 2017 10:17 #181784 by Nissan300
Replied by Nissan300 on topic Re:RE: Re:Grand vitara calipers and discs
11/60 wrote: Forgive my ignorance but do you also need the carrier from the donor or is it just the new caliper that bolts to the existing Jimny carrier?
I've just fitted discs to the rear and want to get rid of the solid front discs and upgrade to vented with larger calipers so yes I will also need the carriers .
  • Nissan300
  • Visitor
  • Visitor
13 Jun 2017 07:57 #181960 by Nissan300
Some pics of my rear disc conversion.
14 Jun 2017 06:34 - 14 Jun 2017 11:54 #181994 by yakuza
Early Vitara lwb calipers will fit your excisting front carriers.
Edit: As Nissan300 pointed out, carriers have to be wider to accommodate vented discs. I have to check my parts at home to see if i used the vitara carriers...
Last edit: 14 Jun 2017 11:54 by yakuza.
14 Jun 2017 06:35 - 14 Jun 2017 06:39 #181995 by yakuza
Nissan300 wrote: Some pics of my rear disc conversion.
Where does these rear calipers come from?
Last edit: 14 Jun 2017 06:39 by yakuza. Reason: trying to include picture in quote...
  • Nissan300
  • Visitor
  • Visitor
14 Jun 2017 06:42 #181996 by Nissan300
Yes they would but my carriers are not wide enough to accept a vented disc. I'm waiting for to postman to deliver vitara lwb discs and calipers with the carriers today can't wait as I love working on my jimny.
Time to create page: 0.168 seconds
