Possibility to shift directly from 2WD-H to 4WD-L and vice versa
18 Jan 2017 16:16 - 18 Jan 2017 16:17 #176951
by Bosanek
According to Suzuki's user manuals, it appears that Jimnys with electric (push-button) transfer box which are made after year 2008 (factory type 7 and newer) have a modified 4WD controller.
According to user manual, this newer 4WD controller allows them to shift directly from 2WD to 4WD-L (without having to press 4WD-H first) and vice versa. The vehicle must still be stationary and I suppose that the clutch pedal must be pressed while doing so.
Can someone, who has a Jimny made in 2008 or later, check this?
I wonder if they modified this, what else might they have modified with those newer ones.
P.S.: Source document: 99011-81a29-01e-jimny_5-operating-your-vehicle.pdf
Last edit: 18 Jan 2017 16:17 by Bosanek.
- Thank you received: 1960
18 Jan 2017 17:02 #176952
Replied by Lambert on topic Possibility to shift directly from 2WD-H to 4WD-L and vice versa
My 2011 does that. Vehicle stopped, clutch down, switch between 2hi and 4lo.
- grumyoldjoe
- Elite Member
- Thank you received: 20
18 Jan 2017 20:25 #176955
by grumyoldjoe
Yep, my 2013 is the same
Wine improves with age.
Replied by grumyoldjoe on topic Possibility to shift directly from 2WD-H to 4WD-L and vice versa
11/60 wrote: My 2011 does that. Vehicle stopped, clutch down, switch between 2hi and 4lo.
20 Jan 2017 07:35 #177049
by Bosanek
Replied by Bosanek on topic Possibility to shift directly from 2WD-H to 4WD-L and vice versa
Thank you for the confirmations. I incorporated the info in the wiki.
