Lift Kit, Vitara, will it work on my Jimny?
- gridge
26 Aug 2016 16:07 #171707
by gridge
Lift Kit, Vitara, will it work on my Jimny? was created by gridge
Hi, picked my Jimmy up this week and love it, i want to lift it up a bit, i have seen a kit that is currently fitted on a Vitara, will it fit the Jimny?
Sump guard
Front axle lowering locating brackets (yellow)
Front springs
Rear springs
Rear shocks
Rear prop spacer
thanks in advance from a newbie
Peter
Sump guard
Front springs
Rear springs
Rear shocks
Rear prop spacer
Peter
- Thank you received: 1854
26 Aug 2016 20:45 #171721
Replied by Lambert on topic Lift Kit, Vitara, will it work on my Jimny?
The vitara is independent front suspension ie like a normal car with wishbones and struts, the Jimny is significantly different being live or solid front axle. The kit for one is not interchangeable with the other.
- gridge
26 Aug 2016 21:30 #171722
by gridge
Replied by gridge on topic Lift Kit, Vitara, will it work on my Jimny?
thanks for coming back to me, whats the cheapest way to lift the "beast" by one or two inches?
27 Aug 2016 05:08 - 27 Aug 2016 05:10 #171725
There's some very cheap kits on ebay but i wouldn't want to recommend them . There are spring spacer sets available from various sources which are both relatively inexpensive and better than a cheap kit off eBay. Then there are proper branded kits that are widely available from recognised suppliers. Ultimately it has all been done before and I would recommend you to use the search box above and have a read through some of the experiences of our fellow members.
Last edit: 27 Aug 2016 05:10 by Lambert. Reason: Predictive text
- Thank you received: 923
28 Aug 2016 08:26 #171779
Replied by X8GGY on topic Lift Kit, Vitara, will it work on my Jimny?
I've done a 'cheap' lift on my "daily driver" Jimny by using Jimny front springs on the back (new off eBay for £15 each) which give the kind of lift you're after, and then another new pair of springs on the front (again £19 each off eBay) with a couple of my spring spacers on the top...
Then, interestingly (by your question above), I used a pair of rear Vitara shocks on the front (inexpensive Monroe adventure) and a standard length pair of Jimny rear Monroe adventures on the back, with a pair of shock repositioners on the rear -
www.bits4vits.co.uk/store/daily-driver-jimny/blog_340.html
Front -
Rear -
Lifted (with 235/75/15s on) -
His big brother -
Front -
Rear -
His big brother -
- gridge
28 Aug 2016 19:40 - 28 Aug 2016 19:41 #171814
by gridge
your jimneys look great, thanks for coming back to me.
Last edit: 28 Aug 2016 19:41 by gridge.
Time to create page: 0.907 seconds
