2" lift on a budget
18 Nov 2010 00:08 - 18 Nov 2010 00:46 #6067 by 1390_taz
2" lift on a budget was created by 1390_taz
i have a 55 plate JLX Jimny to which i wont to modify with a 2" lift chunky tyres and use it to get to work im on a small budget can this be done what is the best size tyre to get without cutting the archers
Last edit: 18 Nov 2010 00:46 by 1390_taz.
  • ooky_123
18 Nov 2010 07:44 #6068 by ooky_123
Replied by ooky_123 on topic Re: 2" lift on a budget
235's are the most common options if you wish to retain as close as possible to the standard Rolling Radius.
We didnt cut the arches per say ... only shaved about 30mm off the bottom of the rear bumper to accommodate our much taller 215 tyres.
  • oxford_bloke
18 Nov 2010 10:36 #6077 by oxford_bloke
Replied by oxford_bloke on topic Re: 2" lift on a budget
On my previous offroader (a Daihatsu Sportrak) i lifted it for about 30 quid, if you get your hands on a meter length of engineering nylon for about 20 quid cut it to 50mm lengths and hey presto a cheap body lift.
Tom
  • darthloachie
18 Nov 2010 12:47 #6088 by darthloachie
Replied by darthloachie on topic Re: 2" lift on a budget
try some spring spacers from bitz4vitz
www.bits4vits.co.uk/store/jimny/cat_17.html
18 Nov 2010 20:57 - 18 Nov 2010 21:06 #6121 by dirtydogz
Replied by dirtydogz on topic Re: 2" lift on a budget
This might help you, go to page 6 on technical,look for eco spring+body lift.This will give you a 2 inch lift.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 18 Nov 2010 21:06 by dirtydogz.
19 Nov 2010 00:08 #6128 by 1390_taz
Replied by 1390_taz on topic Re: 2" lift on a budget
Thanks guys now i have some idea what to fit for the 2" lift my next question is do i need to change the brake lines for longer ones. If i use the 2" body lift a lot of things need to change shorly ????
Time to create page: 0.162 seconds
