Unbraked towing
- Thank you received: 1939
Daniel30 wrote: Sorry quick hi jack of thread
Would I be able to tow a braked 900kg trailer tent?
You will feel it on long inclines but you will be fine though as mentioned above if you have none standard uncorrected gearing you will suffer more
- Northern-Wanderer
Northern-Wanderer wrote: This subject has been covered many times.I cant go into the ins and outs again but pulling a braked trailer rated at 1400kg even if its empty is illegal with a jimmny.I know its stupid but thats the way it is,somethng to do with the trailers stated gross weight.
Not true if you have a full trailer license or are old enough to not need one. However if you passed recently, haven't done the trailer test and want to take advantage of the 'towing up to the unladen weight of the vehicle' rules then the gross weight of the trailer would need to be de-rated to less than the unladen weight of the Jimny.
