Tell me about CB's
16 Jun 2016 21:11 #168691
by mark98
Replied by mark98 on topic Tell me about CB's
Set to UK, so I'm at a total loss as to what the problem is. :dry:
- JuanGuillie
16 Jun 2016 23:06 - 16 Jun 2016 23:10 #168698
by JuanGuillie
Replied by JuanGuillie on topic Tell me about CB's
As "Kirkynut" wrote earlier in this topic, you can cut the aerial to get an optimal reading on the SWR-meter !
I did had the same issue with my CB and this is what the salesman/technician of my CB did to my installation.
First of all he did loosen up a little bit the screw that is on the bottom on the side of the metal rod from your aerial-foot.
This metal rod you can push completely down into this foot and then you lift it a little bit up but make sure the metal rod can be tightened up with te screw, so the ideal position should be somewhere in the middle of both positions.
The reason for him doing this is "finetuning" in the "reflected" knob position on your SWR meter when you're nearly on the lowest SWR reading.
The first readings were too high so he did cut some little bit off from the aerial, calibrated the SWR-meter again (on forward) and then did the test "on reflected", if these readings are still too high just cut again a minor piece from the aerial, calibrate SWR again (on forward) and do the test again "on reflected"... do this until you have a low reading "on reflected" on your SWR-meter.
Take care : if you see that you are getting lower readings "on reflected" don't cut to much from your aerial or you have to start all over again. Then if you're nearly at the lowest reading you can finetune your aerial by loosen the screw on the bottom and put the aerial a little bit down or up until you have the lowest reading.
The ideal should be that the SWR readings on channel 1 and 40 should be as close as can be but the reading on channel 40 will always be higher.
If you do these tests also make sure that you are not in the near of metal roof's or pillars !
Last edit: 16 Jun 2016 23:10 by JuanGuillie.
- 1066Boy
17 Jun 2016 06:04 #168704
by 1066Boy
Replied by 1066Boy on topic Tell me about CB's
Do you know somebody with a good antenna that you can try in your mount ?
Worth checking you have not got a duff SWR meter before trimming the antenna.
Sometimes trimming is necessary but very little. As said before, loosen the grub screw at
the bottom of the antenna and try moving the whip up or down a few mm at a time before
cutting. Its a bugger to stick bits back on! :evil:
17 Jun 2016 06:14 #168705
by kirkynut
Replied by kirkynut on topic Tell me about CB's
Mark I know that you've invested in a mag mount but if you're not getting on with it, people have successfully mounted an aerial on the spare wheel mount with the spare wheel in place. I did it once!
This is what it would be like:
www.google.co.uk/search?q=suzuki+jimny+s...rc=wfLVMAuf-WXnOM%3A
I have seen them for Land Rover Discoveries too but cannot find any for sale.
They're not too hard to make. I think I've thrown my old one out that I made or I'd post it to you!
The mag mount ought to just work as it comes though. It has a built in ground plane. Perhaps find someone nearby with a cb and just make sure you can hear them within a reasonable distance.
Mine is all tuned in perfectly and I tuned a friend's one in and we set off home in different directions and could hear each other for about 4 miles on and off with tower blocks in the way. I'd not expect that from a mag mount though.
The following user(s) said Thank You: mark98
- 1066Boy
17 Jun 2016 06:43 #168706
by 1066Boy
Mag mount works fine. My average range is 5 miles, up to 15 miles if on a high spot.
The antenna tuning and ground plane is the important bit. Center mounted antenna will give best performance
in all directions. Rear mounts work well but the shape of the ground plane will make the signal more powerful
forward and weaker behind you.
17 Jun 2016 07:33 #168709
by mark98
Thanks for the replies, I'm going to move the mount around on the roof to see if that helps. If that fails, then I will find somebody about locally who has fitted a CB to a Jimny, so I can try a good antenna in my mount. I'll also see if there SWR meter reads different to mine.
Time to create page: 0.189 seconds
