First trip out
01 Jun 2016 20:58 #167835 by Keithy
Replied by Keithy on topic First trip out
Not a fan of spacers and bodging in general.
-30 offset wheels with 215/225's tougher sidewalls on the tyres?.....Most of the vehicles in the club I'm a member of are Landrovers.....I tend to have one wheel in one wheel out mostly.
01 Jun 2016 21:55 #167839 by Busta
Replied by Busta on topic First trip out
The trouble with driving in ruts made by bigger vehicles is eventually the ruts get too deep for a Jimny and you get stuck. The solution to being able to drive in landrover ruts is a never ending cycle of bigger tyres, more lift and lower gearing. Without spacers and with decent tyres, that sidewall grip will help you climb out of the rut one side at a time and then you can choose a different route. With spacers, both sides are trying to climb out at the same time and it's twice as hard to get out of the ruts. They also cause the tyres to rub on the arches if you have larger than standard tyres. And they increase bearing wear.
That's from my experience. If the ruts are shallow you are ok, but if yours is the lowest vehicle in the club you will end up dragging your guts everywhere unless you can get out of the ruts!
04 Jun 2016 03:28 #167927 by kirkynut
Replied by kirkynut on topic First trip out
I would not try to get the same track as a Land Rover as it is a bit more than 60mm!
Suzukis run with one wheel out of the ruts created by Land Rovers and this helps you to not get stuck as with both wheels in the ruts you'll bottom out more often and as has been said above, you'll have a never ending pursuit of trying to match bigger tyres to the ruts.
This ends with a well sorted Jimny with a Rocklobster to reduce gearing to cope with the bigger tyres but lots of money spent.
If I was building a greenlaner for not too extreme lanes, so not The Lakes or the trickier ones Wales and Derbyshire have to offer, I would stick with just a 2" lift and 215 / 75 / 15 tyres and a winch.
On the other end of the scale is the ultimate greenlaner such as Dave of Bits4Vits fame's car. A lot of cash has been invested in that though. You need to plan your project as if you'll not be satisfied with my suggested mods and will want to go all out, you'll be better off going for a 3" or 4" lift now and ordering the Rocklobster now too!
  • Terminator
04 Jun 2016 08:10 #167936 by Terminator
Replied by Terminator on topic First trip out
We are fitting the 2" lift kit today and have a set of 215-75-15 mud tyres to go on, just doing a basic service oil change brakes as well.The lanes we went down were not as extreme as some,we grounded out on the tow bar ,so that's coming off.we don't want to spend a fortune,its only for a bit of weekend fun.
04 Jun 2016 13:34 #167954 by X8GGY
Replied by X8GGY on topic First trip out
kirkynut wrote: I would not try to get the same track as a Land Rover as it is a bit more than 60mm!
Thank You Kirkynut, but even mine gets stuck now and again ;)
Interesting, as my new build has a simple 2" lift of new front springs on the back and new frint springs on the front with a pair of spring spacers combined with Monroe Adventure shocks - stanard length on the back with bottom shock spacers / repositioners, and GV rears on the front... a 1" bodylift and 235/75/15 tyres... standard radius arms, KAP adjustable panhards, and a Rockwatt rocklobster on the way... keep it Simple and light this time ;)
  • Terminator
08 Jun 2016 21:00 #168222 by Terminator
Is there such thing as greenlaning etiquette ?is one wheel in a track and one out ,straddling the tracks,Rather than getting stuck.
