My Suzuki Jimny fuel pump will not kick in
- Jim Jimny 95
27 Mar 2016 14:47 #164431
by Jim Jimny 95
My Suzuki Jimny fuel pump will not kick in was created by Jim Jimny 95
Gone out to my car and it will not start the fuel pump doesn't seem to be making a noise and when I turn it over its just constant whining like it wants to start but can't no engine management code, anyone point me in the writes direction would be much appreciated
27 Mar 2016 17:25 #164449
by Rhinoman
Replied by Rhinoman on topic My Suzuki Jimny fuel pump will not kick in
Does the Check Engine Light come on? If it does then I would check the fuel pump relay, if not then check the fuses.
- Jim Jimny 95
27 Mar 2016 19:04 #164462
by Jim Jimny 95
Replied by Jim Jimny 95 on topic My Suzuki Jimny fuel pump will not kick in
Hi there not sure whereabouts the relay is for the fuel pump
- mickt
28 Mar 2016 12:13 #164509
by mickt
Replied by mickt on topic My Suzuki Jimny fuel pump will not kick in
Right by the battery!
- Jim Jimny 95
28 Mar 2016 15:06 #164526
by Jim Jimny 95
There's two I'm guessing the one with the pink wire is the fuel pump relay, checked the fuel pump by using a 12v battery and the pump is working any advice what else I should check
- Jim Jimny 95
30 Mar 2016 20:19 #164665
by Jim Jimny 95
After tinkering about and basically stripping the wiring loom down through the whole car the problem was a bad relay which either sends power to another relay or uses the same earth I then rang Suzuki up and decided to get a price for two new relays, they quoted me a mega whopping £34.25 each, They must be Mande of gold for that price! So in the end I I used two relays off a Vauxhall astra cut the plugs off the wiring loom and used terminal connectors I also made a new earth to the relay and now she starts up first time and no issues upto yet
