knocking sound when I move the steering wheel
  • Barkis21
03 Mar 2016 20:58 #163310 by Barkis21
When I move the steering wheel side to side when stationary there is a knocking sound also can be heard/felt when driving any ideas to save time and effort......
  • Daniel30
03 Mar 2016 21:15 #163311 by Daniel30
Replied by Daniel30 on topic knocking sound when I move the steering wheel
I have the same at the moment had 30 mins to spare so popped over to the garage and we had a look underneath but couldn't see anything visable, wondering if it could be a bottom kingpin on the drives side starting to play up but there is no play in the wheels and only makes the noises when the car is on the ground/underload
  • Barkis21
03 Mar 2016 21:32 #163312 by Barkis21
Replied by Barkis21 on topic knocking sound when I move the steering wheel
Going to take mine to the garage on Saturday if I find out what the cause is ill post it
04 Mar 2016 05:14 #163327 by Lambert
Mine did this. It was the axle end of the front panhard rod bolt that was not done up tight enough and was allowing just a little movement between the mounts and the bush inner sleeve.
The following user(s) said Thank You: Daniel30, Barkis21
  • Daniel30
04 Mar 2016 06:42 #163328 by Daniel30
I'll have a look at that cheers
  • Reloaded
04 Mar 2016 08:17 #163330 by Reloaded
Replied by Reloaded on topic knocking sound when I move the steering wheel
As 11/60 said, but chassis end for me. If the bolt isn't tight enough it shifts as you turn the wheel, I could feel the body move slightly as well.
Time to create page: 0.230 seconds
