what do you do when...
  • davert85
06 Feb 2016 00:50 #161938 by davert85
what do you do when... was created by davert85
Youve got a wetinterior?
Im sure many of you who off road their jims will of at some point had water come in and make a mess of your lovely carpets, mats etc.
I had it in my old jim and just ripped everything out, waxoyled it and put rubber flooring in the whole jim. With my new one i dont wana do this...but i do want to rid myself of my footwell pond.
so, wha do you guys suggest? Dehumidifier? Silica jell stuff?
Thanks in advance
david
  • atnas666
06 Feb 2016 00:58 #161939 by atnas666
Replied by atnas666 on topic what do you do when...
Give it a really good shampoo (with proper stuff). Then a Really good strong dehumidifier will do the trick.. but the smell is the hardist bit to get rid off.
  • Leathery1
07 Feb 2016 20:27 #162089 by Leathery1
Replied by Leathery1 on topic what do you do when...
Silica gel just wont cut it, small dehumidifier will take too long, allowing mould to form which is the main cause of smell and very bad for your health in a closed environment like a car.
Suck as much water out of the carpet as possible with a wet vac including the back if you can lift the carpet. Leave the carpet lifted to allow airflow to the backing. Put an electric fan heater in the car on a thermostat to get the interior to 25 deg C or a bit higher if possible but leave the windows open several inches to allow damp air out. The air movement from the fan is very important.
If you do get a smell, you need a good quaternary deodorizer - your local carpet cleaner should be able to help with a small amount of product to do the job.
Time to create page: 0.279 seconds
