New engine g13b - g13bb
  • George.
30 Dec 2015 22:28 #159377 by George.
New engine g13b - g13bb was created by George.
I've found another engine for the jimny it was advertised as a g13b engine but I've just looked through the photos and it's actually a g13bb engine, will it still work as a straight swap? Supposed to be picking up tomorrow? Thanks George
  • TomDK
30 Dec 2015 23:20 #159381 by TomDK
Replied by TomDK on topic New engine g13b - g13bb
probably a mistake.
The G13B engine is an older twin cam engine used in Swift GTI's in the late 80's. Same block as the G13BB but otherwise completely different.
The one you've found is a direct swap :)
  • George.
30 Dec 2015 23:28 #159383 by George.
Replied by George. on topic New engine g13b - g13bb
Okay so should be okay still considering ive had the engine in and now putting a g13bb so I won't need to change anything transmission whis or electric whis
  • TomDK
30 Dec 2015 23:33 #159384 by TomDK
I'm not sure I understand what you're worried about.
If you Jimny is a G13BB model, then yes just swap it for another G13BB engine. Don't worry about it been called a G13B. It looks completely different.
G13B engine looks like this
  • George.
30 Dec 2015 23:44 #159386 by George.
Yeah okay see mine looks like a g13bb but there's just a couple of little differents like the filler cap position minds dead senter where as othere look off to one side
  • suzukisam
31 Dec 2015 07:12 #159394 by suzukisam
Replied by suzukisam on topic New engine g13b - g13bb
Couple of different g13bb engines some are used in other suzuki models so just a case of swapping auxiliaries etc but some have crank sensor and cam pick up point some only have the cam pick up point so need to see if you have a wire in front of your sump.
They will all be usable but you it may be a case of swapping pick up ring off the end of cam etc
Time to create page: 1.284 seconds
