Suzuki OEM Steering wheel choices
- JamJim
12 Oct 2015 15:43 - 12 Oct 2015 15:44 #153479
by JamJim
Suzuki OEM Steering wheel choices was created by JamJim
hello! i have an 04' GV with the standard steering wheel. I can tell that it has become very brittle and will start falling apart pretty soon. i really like the leatherette wrapped wheels from the SWIFT, SWIFT SPORT and newer VITARA.
has anyone ever done the swap from either of these cars to the GV or JIMNY?
Does anyone know if the splines are the same?
never mind about airbags as my OEM wheel does not have one
... and NO, i do not want to wrap or add a cover to my current wheel
swift...
swift sport
newer vitara
swift...
swift sport
newer vitara
Last edit: 12 Oct 2015 15:44 by JamJim.
- JamJim
13 Oct 2015 12:48 #153555
by JamJim
Replied by JamJim on topic Suzuki OEM Steering wheel choices
nobody...?
13 Oct 2015 13:55 #153557
by Rhinoman
Replied by Rhinoman on topic Suzuki OEM Steering wheel choices
If its a non-airbag steering wheel then you can swap in pretty much any other Suzuki steering wheel, the splines are common. I'm sure that you could fit an airbag steering wheel, I'd have to check.
- Statey
13 Oct 2015 19:06 #153574
by Statey
Replied by Statey on topic Re:Suzuki OEM Steering wheel choices
I do like the swift one! Soo tempting to try
14 Oct 2015 14:37 #153643
by Rhinoman
I have one to try but I've misplaced the clock-spring, I haven't the faintest idea where I've put it
- gusthegorilla
31 Oct 2015 17:22 #154967
by gusthegorilla
Sorry for bringing up this old chestnut again, but I want to take the steering wheel of my 04 hardtop and fit it in my 53 soft top.
Both have airbags.
Can I just swap wheels or do I have to disable the airbag system first?
Gus
Replied by gusthegorilla on topic Suzuki OEM Steering wheel choices
Rhinoman wrote: If its a non-airbag steering wheel then you can swap in pretty much any other Suzuki steering wheel, the splines are common. I'm sure that you could fit an airbag steering wheel, I'd have to check.
Both have airbags.
Gus
Time to create page: 0.251 seconds
