judder vibration at 2,000rpm
- mcvann
17 May 2015 17:32 #144332
by mcvann
Replied by mcvann on topic judder vibration at 2,000rpm
hello, this mounting has been replaced 1st job I did...still same
- roughnready
- Thank you received: 1
30 Aug 2020 15:53 #227557
by roughnready
Replied by roughnready on topic judder vibration at 2,000rpm
Just bought a 2004, 69k on the clock.Same problem but at just under 2k revs. Also had new clutch and exhaust recently. Sounds like running on a rumble stip unless I'm trhrashing it. Judder often results in a stall when reversing or pulling away slowly. Although could just be me I guess.Watching keenly for a fix.
I'm too old for this stuff!
- Thank you received: 1941
30 Aug 2020 16:11 #227560
Replied by Lambert on topic judder vibration at 2,000rpm
Have you serviced it recently and replaced the plugs? I had a problem at 2000 rpm and it was the plugs had not been torqued correctly. Otherwise it could also be the plug leads failing.
- Gravydave
03 Sep 2020 11:51 #227678
by Gravydave
Replied by Gravydave on topic judder vibration at 2,000rpm
Owned 2008 jimny for 2 weeks. 82000 miles on clock i get same bad vibes between 2000 and 2500 revs. Seems to be in 2nd and 3rd gear most noticeably whilst accelerating. If gear changes are timed right I don't experience them at all but miss out on the best acceleration path through the gears. Following this for possible ideas/solutions thanks in advance.
03 Sep 2020 13:07 #227681
On a 2008 its just as likely to be the gearbox on it's way out. They are noted for a bearing lubrication issue between 2005 and 2009. The fix is a rebuild with sealed type bearings.
- Gravydave
03 Sep 2020 15:54 #227685
by Gravydave
Sounds expensive is there anyway of knowing its a gearbox bearing without removal and strip down of gearbox. I still have warranty left on the engine and transmission. It would be good to know cause for sure before wrangling with the warranty. Thanks for any advice.
