Help please on 1.6 liana engine
- Chazg83
How can you tell if it's non vvt as my Jims 2000 non vvtidiotmobil wrote: sure the liana engine is a straight swap nothing to do
Lots to swop over but all doable
Grey pick up Jimny
- Chazg83
Cool, what do you need to swap over to put in the jimny? Cheersj999pre wrote: It's a non vvt. No extra bulge on cam cover or cam activator on front.
Jimny crank pulley
Jimny manifolds with liana injectors
Jimny rocker cover and dip stick
Studs x3 removed from front engine mount liana then remove water way plug and replace with jimny elbow
Jimny thermostat etc into back of liana water pump
Jimny engine mounts complete
Remove liana oil filter housing and fit jimny type (buy new)
Jimny flywheel
Remove alloy bottom plate from liana engine
Jimny water pump pulley and studs
Swap over all the jimny wiring
Think that is it off the top of my head
Grey pick up Jimny
- Chazg83
Ok cool cheers for the help, shouldn't be to bad to doj999pre wrote: Jimny sump and oil pick up pipe
Jimny crank pulley
Jimny flywheel
