Remap Jimny ecu
  • steffan
30 Nov 2014 22:42 #131134 by steffan
Replied by steffan on topic Remap Jimny ecu
I have a 1.6 fitted and would like to have mine mapped but the local remap place say I won't see much gains from it so unsure
  • oilypirate
30 Nov 2014 22:49 #131136 by oilypirate
Replied by oilypirate on topic Remap Jimny ecu
surly if the 1.3 ecu is running a 1.6 engine your down on fuel for a start?
i know the remaps for hdi's etc are no were near 400~500
  • ne-crock
01 Dec 2014 00:16 - 03 Dec 2014 20:25 #131149 by ne-crock
Replied by ne-crock on topic Remap Jimny ecu
lindsay wrote: look too good to be true this one
proracing.co/en-gb/component/virtuemart/...2bhp-detail?Itemid=0
:unsure:
a good video explain those fuel chips
realisticly a waste of money, as said throughout this topic,
Last edit: 03 Dec 2014 20:25 by ne-crock.
  • jim
01 Dec 2014 02:50 #131152 by jim
Replied by jim on topic Remap Jimny ecu
Busta wrote: Gains on non turbo petrol engine are so small it's not worth it. If you want more power, a 1.6 conversion is the cheapest and most effective option.
unfortunately as busta said this is true of non turbo cars,
if you think about it for an old design engine 80 odd bhp isn't that bad. I had a 2009 smart car with a 1000cc turbocharged engine. I took it to a smart specialist for a remapping and the rolling road showed it went from 80-114.3bhp. with the non- turbo version I don't think they even got 3 bhp increase.
03 Dec 2014 20:20 #131456 by Rhinoman
Replied by Rhinoman on topic Remap Jimny ecu
oilypirate wrote: surly if the 1.3 ecu is running a 1.6 engine your down on fuel for a start?
The ECU will adapt to some extent but the real problem is that the torque curve is different and that is what the fuelling is based on so the ECU will be continuously trying to adapt. When you put your foot down from low RPM the fuelling will be wrong at the top end. How much you are likely to gain is anyone's guess, as far as I know no-one has ever had one on a dyno. I did a fair bit of work on the G13BB ECU a few years back, when I get my pick-up back on the road I'll run it on the dyno and see how it works out. I plan on fitting an M16 to my 2006 Jimny next year, there should be good gains from that because the VVT will need to remapped to get rid of the big dip in the mid-range.
04 Dec 2014 00:02 #131469 by Busta
Replied by Busta on topic Remap Jimny ecu
Not really because you are using bigger injectors.
A good rolling road re-map, customized to an individual engine is going to be £400+ for any car. Cheaper 're-maps' for HDIs, TDIs etc are normally just a crude 'one map fits all' job to increase fueling and boost. You can get away with this on a diesel because they don't suffer from running too lean or too rich, but this wouldn't work on a petrol Jimny.
