engine swap to g16b queries
- gus2000
A question. Would it be interesting to verify that the g13 and g16 camshaft had the same lift and the same angles of opening and closing of the valves?
This would allow interchangeability without affecting G16B engine performance
Thanks
Gustavo
- Cider
cam pick up not sure with Baleno
- suzukisam
What do mean did you pull the part with the 2 lobes off the camshaft and swap it with the jimny one ?TomDK wrote: But why not just change the pick up cam. It is very easy to do, and there are already marks on the pick up and the cam shaft it self. I did it when I changed camshafts and head.
If so what did you use james mentioned a small bearing puller ?
Cheers for the help guys
- TomDK
Yes.
My Jimny is a 2003 RHD softtop which has the camshaft pickup ring with 2 lugs.
Some months ago the camshaft seized in the head, so I had to find a new head and camshaft. But here in Denmark we only have Jap built Jimnys with the camshaft with 11 lugs on the pickup ring.
So long story short, I used a standard puller to pull the 2 lug ring off the old ruined camshaft and put it on a new used camshaft I got from a breaker.
When you hold the two camshafts up next to eachother you'll see that it's not that hard to swap these pickup rings. But off course always make a few marks, just in case. I you want, I can take a few pics of the old camshaft and ring tomorrow
- suzukisam
TomDK wrote:
suzukisam wrote:
What do mean did you pull the part with the 2 lobes off the camshaftTomDK wrote: But why not just change the pick up cam. It is very easy to do, and there are already marks on the pick up and the cam shaft it self. I did it when I changed camshafts and head.
Yes.
If you could that would be great thanks
