4" suspension lift, 2" body lift.....
  • RichiesJimny
28 Sep 2014 11:15 - 28 Sep 2014 11:17 #125279 by RichiesJimny
Replied by RichiesJimny on topic 4" suspension lift, 2" body lift.....
3 inch lift with 235's and a very small trim of the arches was fine offroad I did a big trim on the front bumper because it was damaged when I bought the car, I ran with a 410 and a rocklobster transfer box and to be honest I preferred the gear ratios in the 410 box for green laning.
If your doing a 4 inch lift you won't need a body lift with 215/75 tyres you only do a body lift to give you more clearance for the tyres which you won't need.
If your only green laning your much better off with a 2-3 inch lift and a little trim of the arches to try and keep your centre of gravity lower.
Last edit: 28 Sep 2014 11:17 by RichiesJimny.
  • RichiesJimny
28 Sep 2014 11:21 #125280 by RichiesJimny
Have a read through gaz's build I think he's running a 2 inch lift and 1 inch body lift with 235 tyres
www.bigjimny.com/index.php/forum?view=topic&catid=8&id=48276
  • JimnyRiddle
28 Sep 2014 19:29 #125309 by JimnyRiddle
Replied by JimnyRiddle on topic 4" suspension lift, 2" body lift.....
steffan wrote: Rock lobster the 215 80 15s are 9 mm smaller than 235 75 15s but 20 mm narrower so it's something and nothing difference in reality
Sorry for being a bit slow, but do you mean I could run 235's without a crustacean, sorry I mean lobster :silly:
Cheers
Mike
  • JimnyRiddle
28 Sep 2014 19:31 #125310 by JimnyRiddle
RichiesJimny wrote: 3 inch lift with 235's and a very small trim of the arches was fine offroad I did a big trim on the front bumper because it was damaged when I bought the car, I ran with a 410 and a rocklobster transfer box and to be honest I preferred the gear ratios in the 410 box for green laning.
Ye I'll stay away from the body lift then. I already have the 4" kit bought so I'll see how I get on with it being top heavy. :whistle:
Cheers
Mike
  • JimnyRiddle
28 Sep 2014 19:32 #125311 by JimnyRiddle
RichiesJimny wrote: Have a read through gaz's build I think he's running a 2 inch lift and 1 inch body lift with 235 tyres
I'll have a read of it now..cheers
  • RichiesJimny
28 Sep 2014 19:52 #125316 by RichiesJimny
You can run 235's with a standard transfer box but it does struggle to get up to speed on the road, off roading is ok if it's green laning but you do need to be careful you don't ride the clutch to much.
Are you getting castor corrected arms with your lift kit?
Time to create page: 0.339 seconds
