Portable winch, POWERED
  • ZookFastback
  • Visitor
  • Visitor
17 Feb 2014 05:52 - 17 Feb 2014 05:56 #104821 by ZookFastback
Portable winch, POWERED was created by ZookFastback
Hi Folks. Winch time. Years ago I had a winch on the front of my Jimny, along with a Bullbar. Way too much weight so I got rid of both and bought myself a "Come-along" hand winch. This works perfectly if a little slow and bulky (The cable is the bulky bit) in the boot.
"Come-along"
I have recently noticed portable winches that are powered off the car battery with 8' of power lead and corded plus remote. All the gear shown in this pic.
Has anyone used one of these systems yet? I like the idea of only putting the winch in the car when going off-road, keeps the weight down plus you can winch from front or back or even sideways I guess :woohoo:
Last edit: 17 Feb 2014 05:56 by ZookFastback. Reason: Little mistakes
  • steffan
  • Visitor
  • Visitor
17 Feb 2014 06:37 #104823 by steffan
Replied by steffan on topic Portable winch, POWERED
I suppose one of them is ok until your swamped down to your axles and snap the little rope
  • jonesyba420
  • Visitor
  • Visitor
17 Feb 2014 09:54 - 17 Feb 2014 09:56 #104842 by jonesyba420
Replied by jonesyba420 on topic Portable winch, POWERED
only rated to 2000lb (which is less than the jim) so its nowhere near enough, a properly stuck vehicle can weigh 2-3-4 times as much as a non stuck vehicle.
Last edit: 17 Feb 2014 09:56 by jonesyba420.
  • TomDK
  • Visitor
  • Visitor
17 Feb 2014 10:10 #104844 by TomDK
Replied by TomDK on topic Portable winch, POWERED
There is no real alternative to a winch. Even a small 6500lb winch will do for a Jimny. And they don't weigh much. And you don't have to mess around with all sorts of things if you get stuck. Just pull the rope out and winch in :)
  • JerseyJimny
  • Visitor
  • Visitor
17 Feb 2014 10:13 #104845 by JerseyJimny
Replied by JerseyJimny on topic Portable winch, POWERED
I too have looked at this... But you will need to use a bigger winch
You can buy portable mounts for normal winches that uses a hitch to attach to the vehicle
I think ity might be ORA that sells them
17 Feb 2014 13:03 #104866 by Rhinoman
Replied by Rhinoman on topic Portable winch, POWERED
I have a 1700lb winch, from Screwfix, that mounts over the tow bar. I bought it mainly to load cars on and off a trailer but it wouldn't even pull my SJ up the ramps. I can't see a 2000lb winch being much better, OK for an ATV maybe but not a full-size vehicle and definately not one thats stuck.
www.screwfix.com/p/1700lbs-vehicle-winch/35084#
  • gipcyan bill
  • Visitor
  • Visitor
17 Feb 2014 18:42 #104922 by gipcyan bill
Replied by gipcyan bill on topic Portable winch, POWERED
Rhinoman wrote: I have a 1700lb winch, from Screwfix, that mounts over the tow bar. I bought it mainly to load cars on and off a trailer but it wouldn't even pull my SJ up the ramps. I can't see a 2000lb winch being much better, OK for an ATV maybe but not a full-size vehicle and definately not one thats stuck.
i use one simular to that.but my getting stuck is different to the way you guys get stuck
when i got it we had a lump of nearly 1ton metal pipe at work so i used that to tighten the wire up on the pully
it dragged it no bother along the car park but took ages , it seems to have a low gear ratio on it
  • idiotmobil
  • Visitor
  • Visitor
17 Feb 2014 19:07 #104930 by idiotmobil
Replied by idiotmobil on topic Portable winch, POWERED
I had one of these 3000lb winches fitted on the jimny when I got it and you would be extremely surprised where it pulled me out from and never let me down half way up the door in water and mud and that horrible clay type mud for around 30 metres was one of the worst bits
few pics I have of places it pulled me out of
Time to create page: 0.168 seconds
