Bead lock rims
  • TomDK
25 Feb 2014 18:23 #106002 by TomDK
Replied by TomDK on topic Bead lock rims
regular tubes will not keep the bead in place. Staun beadlocks will. But they are pretty expensive :)
  • Yellostreak
25 Feb 2014 18:48 - 25 Feb 2014 18:52 #106005 by Yellostreak
Replied by Yellostreak on topic Bead lock rims
that's the ones I was thinking off.. but I am still of the mind that for mere mortals tubes would be sufficient and definitely better than tubeless..
what are tyron bands by the way.. don't they fit them to caravans and such?
Last edit: 25 Feb 2014 18:52 by Yellostreak.
  • TomDK
25 Feb 2014 18:58 #106007 by TomDK
I don't think regular tubes will do the trick. The pressure is still very low in them, so the bead does not sit any better to the rim, compared to running without tubes.
Remember it's because of low tyre pressure the bead might pop in. And why beadlocks are required for comp use :) putting in a tube, and run the same low pressure does nothing to keep the bead in place.
  • idiotmobil
25 Feb 2014 19:02 - 25 Feb 2014 19:31 #106009 by idiotmobil
Replied by idiotmobil on topic Bead lock rims
I kind of knew the bead lock bit ment about the bead seal I suose it would help
Last edit: 25 Feb 2014 19:31 by idiotmobil.
  • idiotmobil
25 Feb 2014 20:03 #106027 by idiotmobil
I ment about the bead seal bit I kind of knew the beadlocks would do the trick but if I beadseal them surely that should stop the dirt getting in
  • Yellostreak
25 Feb 2014 20:07 #106031 by Yellostreak
Yes I would think so.. ask your tyre fitter to use 'rimseal' instead of the usual white soap stuff.. its what they use on everything up to earthmovers :)
Time to create page: 0.157 seconds
