1.6 conversion worth it off road?
- winter
13 Jan 2014 23:44 #100447
by winter
Replied by winter on topic 1.6 conversion worth it off road?
im running 1.6 one of the best mod iv done so so much better on road n offroad mine dose it all lanes pnp ect ect plus the eng con is so easy to do
- rexthecat
14 Jan 2014 14:48 #100519
by rexthecat
Replied by rexthecat on topic 1.6 conversion worth it off road?
Cheers all, very helpful, think I'll go with the 1.6 and maybe put lower geared diffs in if I feel the need. If I had the cash or the expertise I'd get the V6 but unfortunately not.
- iloveics
14 Jan 2014 20:21 #100589
by iloveics
Replied by iloveics on topic 1.6 conversion worth it off road?
Gaz you running a standard t-box?
- RichiesJimny
14 Jan 2014 20:54 - 14 Jan 2014 20:55 #100593
by RichiesJimny
Replied by RichiesJimny on topic 1.6 conversion worth it off road?
The 1.6 is the well worth doing I run 235 tyres and found I was struggling to keep up with other traffic but with the 1.6 I can easily keep up with other traffic, I also find it's now better on fuel because I don't need to work the engine as hard.
It's also made a big difference off road it can pull from much lower revs now,I've also fitted a 410 transfer box which is ideal for my needs I've also got a rocklobster but I found I prefer the 410's gear ratios.
Gaz still has the Jimny transfer box in with 195/80 tyres but I know he was thinking about fitting larger tyres and a rock lobster or 410 box.
Last edit: 14 Jan 2014 20:55 by RichiesJimny.
- idiotmobil
14 Jan 2014 20:56 #100594
by idiotmobil
Replied by idiotmobil on topic 1.6 conversion worth it off road?
how much are you looking at for the lot fitted no need to ad any labour I would be doing the work is there a cheeper way around it say getting the belleno instead of the gv motor as I guess there cheeper
- RichiesJimny
14 Jan 2014 21:07 #100596
by RichiesJimny
If you have a twin cam m13a none vvt engine all you need is an engine from a Suzuki liana and basically take every thing off the 1.3 and bolt it to the 1.6 you will need a screw in tube to hold the oil filter on but their only £10 ish from the dealers and use the 1.6 injectors.
I don't know whats involved in the single cam 13g engine swap but its probably been covered on the forum.
