shudder in second gear
- foggy
03 Dec 2013 23:05 #94474
by foggy
shudder in second gear was created by foggy
Hi Guys,
Is it the norm for Jimny's to shudder in 2nd gear? Not going mad on the gas but always get vibration in second that seems to transmit up the body of the jeep. (rear)..
Thanks guys
Thanks guys
- Wiltec17
03 Dec 2013 23:08 #94475
by Wiltec17
Replied by Wiltec17 on topic shudder in second gear
My jimny shakes like a shitting dog anything under 2000 rpm. Which is a pain because I used to idle my fiesta round at 1500rpm everywhere unless I was hooning.
- JAGM
04 Dec 2013 09:26 #94498
by JAGM
Replied by JAGM on topic shudder in second gear
My 2005 VVT does that (25,000 miles), but more so when moving off in first gear (although I have noticed it in second gear from time to time). I think Wiltec 17 is right - more revs means less shudder. Sometimes I get the revs just right and there is no shudder at all. I posted some time ago about driving a friend's older (2003) non-VVT (75,000 miles)and how I noticed the transmission was more 'car-like'. Some people replied that the non-VVT gearbox was different. I certainly thought it was smoother than the VVT version - and no shudder at all.
A friend of mine who is a mechanic at a local BMW Dealership says that he could replace the clutch and flywheel if I wanted, but in his experience it may not improve the shudder much - if at all!! He says that many vehicles like the Jimny suffer from this to a greater or lesser degree.
- Biasmechanic
04 Dec 2013 12:48 #94519
by Biasmechanic
Replied by Biasmechanic on topic shudder in second gear
Mine does this too. 2nd gear below 2500rpm you get the vibration and the grrrrrr noise also sometimes when going into 3rd at low revs. Annoying thing on mine is the plastic trim on the outside of the drivers door is loose and rattles with it.
- adamatdraycott
04 Dec 2013 13:01 #94524
by adamatdraycott
Replied by adamatdraycott on topic shudder in second gear
Common problem.
I think people have agreed on here in the past its either a work UJ on the rear prop... or harmonics through the rear diff.
The European Diesel version has a damper hanging from the bottom of the diff helping to reduce this... I assume the diesel has it due to the relatively low rev range used in a diesel because that is were the torque is.
There is a diagram available somewhere
- GuardianAngel
04 Dec 2013 14:34 #94531
by GuardianAngel
Replied by GuardianAngel on topic shudder in second gear
It's just resonance. My J does it. All cars do it at low revs if the engine is under strain.
Time to create page: 0.218 seconds
