WAXOYL vs UNDERSEAL
- jimothy
29 Nov 2013 21:06 #93920
by jimothy
WAXOYL vs UNDERSEAL was created by jimothy
Hi guys
I am about to tackle the surface rust underneath at the weekend and once checked and cleaned is it best to Waxoyl or underseal the scabby bits. Or is this best left until the warmer weather as I intend to start using the Jimny.
30 Nov 2013 02:11 #93945
by facade
Replied by facade on topic WAXOYL vs UNDERSEAL
Doesn't make any difference IMHO, I've tried both and neither work
I seem to have more success removing the rust and daubing with the black Smoothrite copy that you can buy in Aldi for about £7 a litre, called "Metal Paint" or similar
- TLW
30 Nov 2013 04:35 - 30 Nov 2013 04:36 #93947
by TLW
Replied by TLW on topic WAXOYL vs UNDERSEAL
I've found Waxoyl sitting as a nice solid sheet with a layer of water between it and the steel many times. It never seems to do that well in tests. Applying it pretty thinly to pretty clean metal/paint seems to get the best out of it.
Old fashioned thick, bitumen based underseal is OK at sound-deadening but not much else. Once rust starts (and it will) it spreads behind it until a huge area just lifts or falls off revealing the damage. It's also horrible to apply - the DIY spray kits simply don't work, so you need a decent compressor or use spray cans or brush it on (best way in my experience).
The best in most magazine tests (and in my personal exerience) is Dinitrol. The black wax where water, road dirt etc. is likely to be an issue, and the panel wax (the number starts with a 5) for everything else. Both products were originally developed to meet MOD requirements for rust-proofing vehicles that would be immersed in up to 4 feet of sea water. They're not perfect, but in this field nothing is, not even epoxy paint or powder coating applied to sound metal.
If the rust has a hold though you really need to get rid of as much of it as possible first. A key thing with Waxoyl and Dinitrol is to apply it pretty thinly - a thick coat tends not to set properly or to heal itself if scratched.
Unless you've a heated garage I reckon it's way too cold to get anything like worthwhile results at the moment. All these products need to be at room temperature (at least, Waxoyl more unless brushed) to apply. It's also far too cold for rust treatments to work outdoors at the moment as well. The good news is cold weather slows down rust quite a bit.
Last edit: 30 Nov 2013 04:36 by TLW. Reason: typo
- Tadpole
30 Nov 2013 09:39 #93962
by Tadpole
Replied by Tadpole on topic WAXOYL vs UNDERSEAL
I would agree with the above regarding application in the warm.
I did my Jimny back in the 'summer' gave the underside a real good power wash first then left it to dry for a few day prior to applying 'waxoyl.
I'm well pleased with the result hth ........
- jimothy
30 Nov 2013 15:21 #93991
by jimothy
Replied by jimothy on topic WAXOYL vs UNDERSEAL
Yes I think your right. its far to cold. I think I will still remove the seat and carpet tomorrow and see what im left with and apply some Hammerite smooth at least this way I can get the electric heater in the car to dry it out a bit before I start. Its the same old story this time of year the weather is crap and its to cold and damp and it gets dark to early to really do any real worth while jobs. And these sort of rust treatment things take a bit of time. Lets hope no welding needs doing.
- Tadpole
30 Nov 2013 19:54 #94042
by Tadpole
Sounds like a plan, I also splashed a bit of 'Hammerite' around underneath before the Waxoyl ...
Time to create page: 0.599 seconds
