Trivial question manifold guard
  • helijohn
29 Oct 2013 18:29 #88503 by helijohn
Replied by helijohn on topic Trivial question manifold guard
kirkynut wrote: As long as there are no components directly above it I really don't think it will matter. If you add things above it - like the Jimnybits Battery tray goes over it to some extent, you may well want it on, but otherwise, if the studs rust and it starts to vibrate - put it in the bin!
I think we all know not to touch a hot engine manifold and if not you'll soon learn!
Agreed. ;)
And I can now get to the oil filter more easily - bonus. :laugh:
It went in the bin when I removed it TBH!
  • markyp2000
29 Oct 2013 19:59 #88521 by markyp2000
Replied by markyp2000 on topic Trivial question manifold guard
How close does it sit to the coolent bottle and any pas pipes it there for a resome if its not broke ie loose and rattaling why leave it off you will burn your self once and say why the hell didnt i put that shield back on
29 Oct 2013 20:05 #88526 by kirkynut
It's not close enough to anything to make a difference and to be honest Mark, you burn yourself on the shield it gets so hot, so it is kind of pointless!
I wouldn't remove it if there is no reason to do so but if the studs rust out and it starts to vibrate like they do, it's not something that would be missed.
  • helijohn
29 Oct 2013 20:30 #88530 by helijohn
It was rattling the other day cos I had had it off for a looksee and didn't whack it up tight after. :ohmy: It has a warning on it to keep hands off so you gots to avoid it anyway. ;)
It's a good way off other stuff and heat coming off it is pretty intense ; after all it has a little oven under it. :laugh: :laugh:
BTW I am sorry if I get yous two mixed up Kirk and Mark. :blush: :blush:
  • little jimny
29 Oct 2013 20:34 #88532 by little jimny
Replied by little jimny on topic Trivial question manifold guard
That heat shield is missing on mine, and has been the whole two and a half years I've had it with no ill effects.
Having said that, if you don't want it I'll take it and the securing bolts off your hands if you'd post them!
  • helijohn
29 Oct 2013 21:06 #88540 by helijohn
little jimny wrote: That heat shield is missing on mine, and has been the whole two and a half years I've had it with no ill effects.
I just binned an SJ one I'd had in the loft for years and years.................if I'd known and if it fitted....... :ohmy:
Time to create page: 0.156 seconds
