Do Jimnys have OBD2 ports?
  • Keefe
18 Jul 2012 08:55 #44456 by Keefe
Replied by Keefe on topic Re: Do Jimnys have OBD2 ports?
2001 Tin top M13A engine
Got the port, got the scanner. BUT it is one of the, 'Not gonna work in a million years' type. :laugh:
18 Jul 2012 10:11 #44461 by Mud_Muppet
Ive borrowed a friends scan gauage jobby. Brilliant bit of kit for offroading told me what volts i was running when winching and also the water temp the engine was running at !! So so cool aswell
2001 Red Tin Top,
4.5 inch ORA lift kit,
Pro Comp steering damper
Kap Winch Bumper,
White Weller offset Rims with 30" Insa Turbo Special Tracks,
CB Radio,
Stripped Interia
Roof Rack with 4 front Wipac,
Rear Wipac recovery Lights
.....Plenty more on its way !!!!
  • reaper
18 Jul 2012 10:11 #44462 by reaper
Replied by reaper on topic Re: Do Jimnys have OBD2 ports?
Will depend what scanner and what part of 2001 it was built , some have the port but are only obd1 connected
18 Jul 2012 10:18 #44463 by mlines
Keefe wrote: 2001 Tin top M13A engine
Try here, www.rhinopower.org/
Tell Jamie I sent you.
The following user(s) said Thank You: Keefe
  • Keefe
18 Jul 2012 10:43 - 18 Jul 2012 10:44 #44464 by Keefe
Cheers Martin, will have to have a little looksee at that. ;)
I thought it was my reader that was at fault at first but after plugging it in various other vehicles etc, it works perfectly.
Must be one of those borderline Zooks? :laugh:
Thanks.
Last edit: 18 Jul 2012 10:44 by Keefe. Reason: spullinj
  • vegetablejoe
24 Jul 2012 06:24 #44795 by vegetablejoe
Replied by vegetablejoe on topic Re: Do Jimnys have OBD2 ports?
I looked under my dashboard briefly this morning, and couldn't find the OBD2 port. :(
Could it be that the factory in Japan excludes this port (as it does with the ABS and airbags) when it assembles CBU units for the Philippines?
