Bump Stops
- oxford_bloke
09 Aug 2010 10:44 #4143
by oxford_bloke
Bump Stops was created by oxford_bloke
I have just ordered, a 4.5 inch lift off of ORA, and realised that on some trucks removing the bump stops will increase the compression, I'm hoping to have 33's on her, and enter winch challenge events.
So in short shall I remove the bump stops or leave them there?
- darthloachie
09 Aug 2010 10:52 - 09 Aug 2010 10:53 #4147
by darthloachie
Replied by darthloachie on topic Re:Bump Stops
There aren't any on mine.
The tyres hit the wheel arch extensions first - good job they are fixed on with self tappers
Last edit: 09 Aug 2010 10:53 by darthloachie.
- oxford_bloke
09 Aug 2010 12:06 #4149
by oxford_bloke
Replied by oxford_bloke on topic Re:Bump Stops
cool cheers for that. im gunna put some KAP grp wings on it I think. so have you removed both the bump stops in each corner as there is one inside the spring also.
Cheers
Tom
Cheers
Tom
09 Aug 2010 15:28 #4153
by Obarno
Replied by Obarno on topic Re:Bump Stops
Personally I would leave the bump stops as on full compression either the spring will become bound, or the shock will bottom out and may damage itself. Neither of these is a good way to stop axle movement! It would be worth checking out what happens on full upward movement of the axle with the big tyres fitted.
Infact on my Sammi I have lowered the front bump stops to stop the tyres getting cut on the inside of the wheelarch.
09 Aug 2010 22:27 #4157
by kirkynut
Replied by kirkynut on topic Re:Bump Stops
Obarno wrote:
What he says!
What he says!
Time to create page: 0.170 seconds
