Body lift extras?
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 16:54 #39509 by Smoggy
Body lift extras? was created by Smoggy
I notice on the Jimnybits website that they sell steering spacers and pitman drop arm. Before I fit my 2'' bodylift kit can anyone recommend whether they deem that these extras are necessary/recommended. Just want to avoid any probs when I do the job. If there is any other recommendations you can make apertaining to the bodylift then any help would be greatly appreciated.
07 May 2012 17:02 #39510 by X8GGY
Replied by X8GGY on topic Re: Body lift extras?
Steering box is connected to the chassis, so it won't move in a bodylift...
  • myers647
  • Visitor
  • Visitor
07 May 2012 18:02 #39515 by myers647
Replied by myers647 on topic Re: Body lift extras?
Hi mate Iv not done the body lift myself but Iv seen a couple. You will definately need to extend the main steering shaft and either bend the Transferbox lever or cut the tunnel an inch so that it will still engage.
Thanks
James
  • supergaz
  • Visitor
  • Visitor
07 May 2012 19:07 #39525 by supergaz
Replied by supergaz on topic Re: Body lift extras?
The steering shaft still should fit without spacers, spacers are only really needed with a 3" body lift.
The pitman drop arm is for suspension lifts, I will get one from jimnybits soon, but its not desperate.
I will replace my rod ends at the same time of fitting a pitman drop arm.
I've the jimnybits bodylift and its perfect, the transferbox lever will need bending slightly.
I think I could do a bodylift in 1h30 max.
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 19:25 #39528 by Smoggy
Replied by Smoggy on topic Re: Body lift extras?
omg 1.5 hrs thats sounds pretty fast. It will probably take me all day, mind I tend to fanny about with these things!
Listening to what youve said, do you think it might be prudent to get a drop arm anyway, bearing in mind im doing a 4.5'' spring lift too. (though it looks as though they have been out of stock forever)
  • supergaz
  • Visitor
  • Visitor
07 May 2012 19:52 - 07 May 2012 19:53 #39530 by supergaz
I've 4.5"lift and will be fitting a pitman drop arm. I asked Rus at jimnybits and they should be in very shortly.
Once you have fitted a bodylift its easy the second time as you know exactly every nut and bolt.
I have also done the same with a pajero lwb and to be honest that is easier. And I use my cordless impact gun, the best tool in my van!
Last edit: 07 May 2012 19:53 by supergaz.
07 May 2012 20:26 #39534 by j999pre
Replied by j999pre on topic Re: Body lift extras?
supergaz wrote: I've 4.5"lift and will be fitting a pitman drop arm. I asked Rus at jimnybits and they should be in very shortly.
How about a comprehensive list of what to loosen etc for doing a body lift. I'm sure it would be a great help to anyone contemplating such a job.
Grey pick up Jimny
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 20:29 #39538 by Smoggy
Yeah luckily ive got a compressor driven jobby. Bit more cumbersome though :)
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 20:31 #39541 by Smoggy
Now theres an idea. If anyone has time that is.
If not, Il try to log it as I go along.
  • supergaz
  • Visitor
  • Visitor
07 May 2012 20:48 #39547 by supergaz
Always plan to take photos, but get stuck in and dirty and forget.
Here is my tips and i'm sure others can add to this.
Remove steering shaft bolt so shaft can slide.
Disconnect brake splitter from chassis rail (drivers side)
Extend (adjust) brake pipes at the front where they come through inner wing
Disconnect fuel filler pipes
Remove headlights
Undo bolts under headlights
Then 6 more that bolt chassis to body
Jack body up one side at a time only so body stays square to chassis.
(remember body needs to go up 4" to get 2" blocks in) The bolts are welded to body, hence the jimnybits kit is so good having the extended nuts.
I am unsure of other kits available, they ebay bodylifts don't generally have these and require the fixed body bolts removing and long bolts right through which is a'lot more work.
No idea with standard bumpers as I've not got original bumpers.
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 21:02 #39548 by Smoggy
supergaz wrote: Always plan to take photos, but get stuck in and dirty and forget.
Remove headlights
Thanks Gaz, il try to add to it with some pics.
  • Smoggy
  • Visitor
  • Visitor
07 May 2012 21:13 #39550 by Smoggy
Was there anything else you wish you had done along the way whilst doing the bodylift. eg Rust clearing behind headlamps etc.
