12v/24v winch wiring
  • oxford_bloke
28 Apr 2012 19:19 #38794 by oxford_bloke
12v/24v winch wiring was created by oxford_bloke
guys,
I want to run 2 x 12v winches, with 24v to each one for faster does anybody have a wiring diagram or the knowledge of how to do this?
cheers
  • Blakey
28 Apr 2012 19:32 - 28 Apr 2012 19:33 #38795 by Blakey
Replied by Blakey on topic Re: 12v/24v winch wiring
You can get the converter from goodwinch that does it think its about £200. I have gone down the route of having a 24v alternator and two batteries for my winch then running the standard alternator for the ingnition sysytem.
Last edit: 28 Apr 2012 19:33 by Blakey.
  • TomDK
28 Apr 2012 19:36 #38797 by TomDK
Replied by TomDK on topic Re: 12v/24v winch wiring
oxford_bloke wrote: guys,
cheers
What winch do you have? Is it up to the 24 volts?
  • oxford_bloke
28 Apr 2012 19:41 #38798 by oxford_bloke
Replied by oxford_bloke on topic Re: 12v/24v winch wiring
I have done a bit of research and chatting to friends, Running a 12v winch of of 24v reduces the amount of current drawn however burns the motors out quicker (approx 2 years heavy winching)
how did you fit a 24v alternator? any pics? my ideal would be to use the standard alternator but i think it isn't man enough
cheers
  • Blakey
28 Apr 2012 19:48 #38799 by Blakey
The alternator is off a toyota coaster its the same setup as rob at ORA had on his Jimny. It fits with a tiny bit of fabrication to the brackets. Not got the Jimny to take any pictures as it is at ORA having some work done. When i was building the truck i was looking at going 12v but changed my mind but i went to the local car electrics place and told the chap i was after a bigger output alternator and he listed loads that would fit in the space of the standard one that would be man enough to run one of the goodwinch boxes.
  • oxford_bloke
28 Apr 2012 19:54 - 28 Apr 2012 19:56 #38800 by oxford_bloke
is there a way round buying the converter? I have a friend that has done it but he is in the navy and away for a few months!
another question what batteries have you fitted? was looking at the Numax CXV-X but got a feeling i might struggle to get 2 under the bonnet
Last edit: 28 Apr 2012 19:56 by oxford_bloke.
Time to create page: 0.117 seconds
