play in cv joint.
- nicho
23 Mar 2012 19:10 #36232
by nicho
play in cv joint. was created by nicho
faild mot, play on cv joint packed it with grease and got it passed wots it likely to be as packing it was just a tempry thing to get it through mot but it drove ok before realy.
23 Mar 2012 19:23 #36234
by mcjimny
Replied by mcjimny on topic Re: play in cv joint.
I would say the play is in the kingpin bearings. I can't see how they can determine there's play in the CV without removing the halfshaft.
The following user(s) said Thank You: nicho
- nicho
23 Mar 2012 19:32 #36235
by nicho
Replied by nicho on topic Re: play in cv joint.
thats what i was thinking ther isnt much wobble though.thers a little one if you hold the steering wheel losely ,but stops if you hold it firmer.
- Johnniehec
- Thank you received: 56
26 Mar 2012 09:33 #36368
by Johnniehec
Jack up front wheel, grab top and bottom, if there's play it's the king pins repeat with the other wheel.If there's play when you try by holding the wheel right and left (front and back) that would be track rod end or maybe the steering box, that's the one you're likely to be feeling through the steering wheel
I don't know how the MOT man could say it was play in the CV, I too think he meant King pins.
John.
Replied by Johnniehec on topic Re: play in cv joint.
nicho wrote: thats what i was thinking ther isnt much wobble though.thers a little one if you hold the steering wheel losely ,but stops if you hold it firmer.
John.
- ianR
26 Mar 2012 10:01 #36371
by ianR
Replied by ianR on topic Re: play in cv joint.
Where can you get cv joints from as I snapped mine yesterday at a play day ?
- doncarlyon
26 Mar 2012 10:25 #36373
by doncarlyon
Replied by doncarlyon on topic Re: play in cv joint.
Get a second hand shaft from cam suzuki... easy swap!
Time to create page: 0.149 seconds
