What's needed to fit a lobster box?
  • Coletti
  • Visitor
  • Visitor
14 Mar 2012 18:17 #35527 by Coletti
What's needed to fit a lobster box? was created by Coletti
I'm thinking of buying a rock lobster box for my 1998 jimny but was unsure as to what parts are needed to fit it and where the best place to get them is? Any information would be greatly appreciated
  • reaper
  • Visitor
  • Visitor
14 Mar 2012 18:39 #35532 by reaper
Replied by reaper on topic Re: What's needed to fit a lobster box?
All will depend on what it comes with , if its just a box you will need flanges a font prop speedo sensor and i think a mounting kit
  • bigoffroader
  • Visitor
  • Visitor
14 Mar 2012 19:32 - 14 Mar 2012 19:33 #35548 by bigoffroader
Replied by bigoffroader on topic Re: What's needed to fit a lobster box?
You will need
Lobster box
T/box mounting brackets
T/box bolt throught mounts
Speedo gear and sensor mounting bracket
Sj front prop ( to use on the rear of the jimny)
Sj middle prop
correct Large flanges and prop (hard to get hold of) or ( medium flanges and prop and drill your diff flanges to match)
Bend the gear sellector on the lobster box to clear the jimny opening
and as it happens ive just finnished another Lobster box that is ready for sale ;) £350 with warranty
I also have (at an extra cost)
mounting Brackets for jimny
speedo gear and bracket
middle prop
medium flanges
and i can bend the gear sellector if needed?
so all you would need to fit it is
sj front prop and bolt through T/box mounts
Last edit: 14 Mar 2012 19:33 by bigoffroader.
  • Coletti
  • Visitor
  • Visitor
14 Mar 2012 20:00 #35551 by Coletti
Replied by Coletti on topic Re: What's needed to fit a lobster box?
How much extra are we talking and I would need it posting if possible so how much posted? Unless you live in Lincolnshire that is
  • Coletti
  • Visitor
  • Visitor
14 Mar 2012 20:06 #35553 by Coletti
And I take it the props that are already on the jimny will not marry up to the tbox?
  • supergaz
  • Visitor
  • Visitor
14 Mar 2012 20:21 #35555 by supergaz
Replied by supergaz on topic Re: What's needed to fit a lobster box?
Only the front prop can stay in place, though you will need to re'drill the transferbox flange to match up the holes.
Finding the correct flanges is a headache and can be costly if buying new.
I had to use 2 prop spacers with my mini sj prop to fit and they are not cheap, I'm still after a longer sj mini prop about 45mm longer.
Bigoffroader is offering a good deal, bending the lever took me a good hour with heat, having a 2" body lift also meant extending the shaft.
  • bigoffroader
  • Visitor
  • Visitor
14 Mar 2012 20:23 #35557 by bigoffroader
Your front prop will fit but you will have to re-drill the flange to match and the jimny centre and rear props wont fit unless you have them machined to fit, most just get SJ props to save on hassel.
I will pm you a price for everythin except the T/box mounts and sj front prop.
  • Coletti
  • Visitor
  • Visitor
14 Mar 2012 20:49 #35558 by Coletti
Thanks for all the info guys and you have a pm bigoffroader, just need to find my self a front prop and Bolt through tbox mounts :)
  • bigoffroader
  • Visitor
  • Visitor
14 Mar 2012 21:01 #35559 by bigoffroader
No eBay APP ID and/or Cert ID defined in Kunena configurationThese are the through mounts i used they work a treat with no vibrations
  • MysticRich
  • Visitor
  • Visitor
14 Mar 2012 21:25 #35567 by MysticRich
Replied by MysticRich on topic Re: What's needed to fit a lobster box?
Their the same mounts as I,ve fitted and are spot on
