How low can you go with big tyres?
  • X-Eng Simon
14 Mar 2012 08:20 #35497 by X-Eng Simon
Replied by X-Eng Simon on topic Re: How low can you go with big tyres?
37" With quite a lot of hacking around though ;) .
As mentioned, by savagely cutting the arches, you can gain 60mm or so radius. However, once that's done, the limiting factor is the width not the height. Extending the wheelbase by a couple of inches makes quite a big difference to what you can run.
Si
  • Paul4x4
14 Mar 2012 10:38 #35501 by Paul4x4
Replied by Paul4x4 on topic Re: How low can you go with big tyres?
reaper wrote: you seem to be missing tge point paul
we fit big tyres to gain ground clearence but in doing so it reduces articulatulation , so then we add spring lift
yes it raises c.o.g. but the benifts are a worth it.
if yoy dont use lift then its wings and most of the inner wings thay need removing at which point you are no longer road legal
No, I'm not missing anything. When you fit big tyres, you need to limit suspension travel in, I get that, BUT even though one would think you would lose a lot of articulation by doing so, you actually don't.
You only need like 2-3" of in travel, and you limit it to that with bumpstops. And when the axle articulates, the wheel pushes the axle against the bumpstop and that actually levers the wheel on the other end of the axle downwards. So in other words, what you loose in travel in, you get that back in travel out. And this is based on my own observations.
And when it comes to road legality, I don't have all the stupid rules that you guys might have there in the UK as I live in Finland...
  • doncarlyon
14 Mar 2012 10:44 - 14 Mar 2012 10:45 #35502 by doncarlyon
Replied by doncarlyon on topic Re: How low can you go with big tyres?
You seem to have your own opinion and dont want to listen to anyone elses... so why dont you just get on with it??
Last edit: 14 Mar 2012 10:45 by doncarlyon.
  • Paul4x4
14 Mar 2012 10:51 #35503 by Paul4x4
doncarlyon wrote: You seem to have your own opinion and dont want to listen to anyone elses... so why dont you just get on with it??
That's exactly what I'm going to do!
I didn't ask for anyone's opinions, but instead wanted to see if anyone else liked to keep their trucks as low as possible, and maybe see some photos of those "low riders" with big tyres. :-)
  • reaper
14 Mar 2012 11:37 #35504 by reaper
Replied by reaper on topic Re: How low can you go with big tyres?
you wont find any , because we all do it the tryed an tested way ......yoy feel free to do it your way as you seem to just want to tell everyone else they are wrong
  • darthloachie
14 Mar 2012 12:15 #35505 by darthloachie
Replied by darthloachie on topic Re: How low can you go with big tyres?
have a look at this thread
www.bigjimny.com/index.php?option=com_ku...itstart=12&Itemid=75
the icelandic jimnies are the lowest i've seen with big diameter wheels
Time to create page: 0.228 seconds
