Rear Towing Eyes.
  • wanderinstar
  • Visitor
  • Visitor
30 Mar 2012 13:33 #36596 by wanderinstar
Replied by wanderinstar on topic Re: Rear Towing Eyes.
Its OK Gaz. Just looked at the ones I have got. They look plenty big enough. Just have to dig the Mig welder out of the garage. I have a few patches to go in usual spots in rear floor.. But can I find my tinsnips???
Not a chance.
  • supergaz
  • Visitor
  • Visitor
30 Mar 2012 16:32 #36612 by supergaz
Replied by supergaz on topic Re: Rear Towing Eyes.
A jimny won't kill those lifting eyes, they have a mega safety factor, they will rip your jimny in 2 first!
  • darthloachie
  • Visitor
  • Visitor
31 Mar 2012 06:17 - 31 Mar 2012 06:19 #36637 by darthloachie
Replied by darthloachie on topic Re: Rear Towing Eyes.
Attachment wagtailday012.jpg not found
we were recovering back in black at wagtail and the rear towing eye on his jimny just folded
Last edit: 31 Mar 2012 06:19 by darthloachie.
  • adamjimny
  • Visitor
  • Visitor
31 Mar 2012 07:07 #36638 by adamjimny
Replied by adamjimny on topic Re: Rear Towing Eyes.
My original ones folded like cheese also
sent from my Samsung Galaxy S2 using Tapatalk
  • supergaz
  • Visitor
  • Visitor
31 Mar 2012 07:19 #36639 by supergaz
Mine ripped the towbar mounts nearly clean off the chassis.
  • wanderinstar
  • Visitor
  • Visitor
31 Mar 2012 21:56 #36667 by wanderinstar
I have finally come up with a design for my rear towing eyes.
I was given 2 eye bolts. I intend to weld one into the inside of a piece of 1" angle iron. I will then grind a couple of holes through the back of the 2nd piece of angle iron. Put the 2 pieces together and seam weld them. Will then plug weld through the 2 ground out holes. I will then find some suitable thickness steel to pack the oblong hoe under the chassis rail. Weld it all together and then wed it to the chassis rail
They say a picture paints a thousand words. I thought the steel was in the back yard. Will add some photos tomorrow.
  • wanderinstar
  • Visitor
  • Visitor
01 Apr 2012 18:03 #36722 by wanderinstar
Here are the photos. Couldn,t do any welding because the last time I used the CO2 it was 3/4 full. That was about 2 years ago. the bl***y bottle was empty. Sod it. Anyway the pictures may help.
[attachment:1]Rear T.E.jpg[/attachment]
  • wanderinstar
  • Visitor
  • Visitor
01 Apr 2012 18:19 #36725 by wanderinstar
Then the second piece of angle is placed over the first one and the edges seam welded and the eye bolt is plug welded
This is then packed out with steel strip to suit.
This is then inserted into the oblong hole beneath the chassis section.
This hole is part of the fabrication fot the tie don eyes. This is then welded up
  • sully
  • Visitor
  • Visitor
04 Apr 2012 17:35 #36939 by sully
Replied by sully on topic Re: Rear Towing Eyes.
here's a pic of mine on my tow bar
  • Tommo
  • Visitor
  • Visitor
20 May 2012 22:08 - 20 May 2012 22:09 #40830 by Tommo
Replied by Tommo on topic Re: Rear Towing Eyes.
THE cheapest way for a strong towing eye
what I did yyou can do it either front or back doesnt matter
as long as the original towing eyes are still shape and not bent
the towings eyes bend easy and any thing
so all you need is 2 bolts, 1 threaded bar, 1 or 2 D shackles, and a putlug ( scafold tube cut down to size
once the pole is to size, drill a whole through it for the shackle/s
if it wont go round, use a club hammer to dent/ crimp the pole
then offer the pole up into place between the towing eyes, the threaded bar runs though the pole and towing eyes then just washers and bolts either end and do it up tight
its as strong as any thing
ive taken run ups at trying to tow people out lifting the jeep in the air and nothing bends
Last edit: 20 May 2012 22:09 by Tommo.
  • wanderinstar
  • Visitor
  • Visitor
21 May 2012 08:56 #40840 by wanderinstar
I now have a towbar to fit on my Jimny. Would I need to fit a nut on the back of the lifting eye, or would it be strong enough just to weld round the front of the eye. The actual bar is a piece if 2" square tube, so would not be easy to fit the nut to the back.
21 May 2012 10:18 #40841 by kirkynut
Replied by kirkynut on topic Re: Rear Towing Eyes.
MysticRich wrote: Has anyone actually had any problem with the original eyes ???
I still have my original eyes and havnt had any problems and my mate used his to rescue discos 90,s and even a big land crusier. I have the ora rear bumperlike most and have plenty eyebolts laying aroundbut havnt changed mine.
Don't use the old style ORA bumper for recovery as it's not designed for that, only as a bumper that can take more knocks and bangs than the standard one.
This is my rear recovery point - a rather large half ring of steel welded very thoroughly to my tow bar!
