Caling all KingPin bearing replacement EXPERTs
  • Keefe
  • Visitor
  • Visitor
06 Mar 2012 11:25 #35028 by Keefe
ZookFastback wrote:
Expert
A simple word that requires a little breaking down in order to make it more understandable...
Remember this next time someone describes themself as "An Expert"
First part of the word is "X" which stands for "The Unknown Factor"
Second part of the word is "Spurt" which, as we all know, is simply...
"A drip under pressure!"
No! The 'X' bit is for 'Has been'.
:laugh: :laugh:
07 Mar 2012 13:35 #35100 by maverick
All races tapped out (without need of heating) with a strong hole punch (metal pointy chisel) and my trusty BFH.
New BigJimny King Pins and shaft seals arrived today (thanks Martin) - I'm now just waiting delivery on Waterproof Grease!
JalapeƱo, IISY?
  • doncarlyon
  • Visitor
  • Visitor
07 Mar 2012 13:59 #35101 by doncarlyon
This is a good guide for anyone else looking - www.jimny.se/kingpinbearings.html
07 Mar 2012 14:32 #35102 by maverick
great link - i love the idea of leaving the top King Pin until last and therefore filling the void with grease through the top King Pin hole ...
JalapeƱo, IISY?
  • wanderinstar
  • Visitor
  • Visitor
13 Mar 2012 07:32 #35416 by wanderinstar
Replied by wanderinstar on topic Re: Caling all KingPin bearing replacement EXPERTs
Err, just read this thread. I seriously hope you didn't fill the inside of the ball housing with grease/ You are only supposed to put about 100ml of grease in the u.j. and that's it
13 Mar 2012 12:47 #35435 by maverick
thats not what is said here - www.jimny.se/kingpinbearings.html
And where is the UJ ... unless your getting confused witht CV (Constant Velocity Joint) ??
JalapeƱo, IISY?
13 Mar 2012 13:11 #35437 by mlines
Definitely do not fill the knuckle with grease. Certainly liberally apply the grease.
If it is full then the grease as nowhere to go when warm. It will either expand its way out of the large swivel seal at the back or, worse still, break the CV through hydraulic pressure.
13 Mar 2012 13:17 #35439 by maverick
Martin,
So i can liberally apply the waterproof grease to the CV Knuckle and around (inside/under) the King Pins - no more anywhere??
JalapeƱo, IISY?
  • wanderinstar
  • Visitor
  • Visitor
13 Mar 2012 15:29 #35444 by wanderinstar
Maverick is right Martin. It does say "Take out top kingpin to fill knuckle with grease...and empty the tube(s) of grease into the ''hole'' vacated by the top kingpin. Repeat this procdure with the second tube.
NOTE; Fill the steering knuckle with at least two or three 100 gram tubes of grease. Do not overfill as it could
effect the steering.
I prefer three tubes of grease. It fills the knuckle pretty good but not to much. To much grease could make it
hard to stear the car. To little makes the lower bearing life short.
NOTE; Use your finger to force-feed the grease. Clean the mounting surface of top kingpin before applying
silicone sealant"
That is off the SE site. Obviously an oversight Martin.
  • wanderinstar
  • Visitor
  • Visitor
20 Mar 2012 10:12 #36013 by wanderinstar
Any advice as to which of these statements is correct/
British Forum says to just fill bearings eith grease.
Swedish Forum says to put 3 Tubes of grease into steering knuckle before inserting top kingpin.
20 Mar 2012 10:43 - 20 Mar 2012 15:04 #36017 by mlines
the guides, including mine, are written by happy amateurs. However, I tend to follow the workshop manual from Suzuki which states that 150grams should be used, which is quite a small amount. Therefore I tend to use slightly more than this, ensuring that everything has a nice covering but not too much. Filling the swivel is a Landrover technique.
The M13AA Manual....
The G13BB Manual....
Last edit: 20 Mar 2012 15:04 by mlines.
