SJ casef fitted, but 4wd light's don't work...
  • Monkey
  • Visitor
  • Visitor
04 Mar 2012 08:43 #34782 by Monkey
Hi guys,
What have people done to get there 4wd light's on the dash to work (or go away) with a samurai case fitted?
What sensor have people used? The jimny sensor of the chai drive case, of the samurai case?
Cheers,
Andrew
04 Mar 2012 11:03 #34792 by Obarno
Hi - I had exactly this problem with my VVT with a rocklobster - have a look at this thread and hopefully will solve your problem
www.bigjimny.com/index.php?option=com_ku...7&id=11993&Itemid=75
  • Monkey
  • Visitor
  • Visitor
04 Mar 2012 11:13 #34793 by Monkey
Thanks for the link mate, but what wire did you connect to the sensor? (a picture would paint a 1000 words;) cus i hate wring) :laugh:
  • Monkey
  • Visitor
  • Visitor
04 Mar 2012 11:22 #34794 by Monkey
I just ground the red/white, red/blue and the light's went off B)
Now, are the lights on the dash meant come on when your in 4wd?
04 Mar 2012 11:31 - 04 Mar 2012 11:35 #34796 by Obarno
I didn't use any of the original vvt transfer case wiring - I just tied it up out of the way and covered it with insulating tape. I ran a new wire from the red/blue under the dash that plugs into the 4 wd drive controller - I cut the wire that went into the plug - and extended it down to the original sammi switch on the transfer case and then ran a wire from the other side of the switch to earth. Sorry can't send you a pic as I am in the UK and the car is in France!
By using the red/blue wire the 4wd light only will come on. When you use low range, only the 4wd light will stay on. This is because the sammi transfer box has only one switch.
By unplugging the yellow connector under the dash the push button lights on the dash will be extinguished - as long as you don't push them again!
Make sure you put the plug back into the controller otherwise your air con won't work.
Edit
Looks as if we overlapped. The lights on the dash will stay off and won't work.
Edit again!!
As I look out of the window here its snowing - betr its warmer where you are!
Last edit: 04 Mar 2012 11:35 by Obarno.
  • supergaz
  • Visitor
  • Visitor
04 Mar 2012 17:23 #34826 by supergaz
I used the sensor from the jimny case, it fits straight on the sj case.
04 Mar 2012 18:33 #34839 by Obarno
Just to clarify, the lights by the radio won't come on, but the 4wd light by the speedo will
Time to create page: 0.149 seconds
