I need help with lifting my jimny!
- Skinhead
- Visitor
03 Mar 2012 13:52 #34721
by Skinhead
I need help with lifting my jimny! was created by Skinhead
Hi all, im new to this site and 4x4ing so go easy please. In the next few week im planning to fit a 2" bodylift and a 2" spring lift to my jimny (im out of work at the min so im on a budget) so far i know im going to need extended brake hoses and shock extentions/repositioners. But is that everything???? Im told i will get away without the steering spacers? Castor correction bushs have been mentioned, but do i need them? An a prop shaft spacer has also been mentioned, do I realy need that? An is there anything else? It seems to be more an more an its putting me off! Do i need these things an what problems will i have if i dont get them??? Any help would be appriciated, thanks.
- oxford_bloke
- Visitor
03 Mar 2012 14:21 #34722
by oxford_bloke
Replied by oxford_bloke on topic Re: I need help with lifting my jimny!
what do you want to use it for ? pay and play days/greenlaning? etc there are various choices depending on what you want to do, also what sort of tyres are you looking at using?
- Skinhead
- Visitor
03 Mar 2012 15:19 #34726
by Skinhead
Replied by Skinhead on topic Re: I need help with lifting my jimny!
I use it mostly on the road but now an then i will do abit of green laning an maybe abit of pay and play (nothing too extreme). Ive got all terrain tyres on 195/r15,
Thanks
Thanks
- oxford_bloke
- Visitor
03 Mar 2012 16:03 #34729
by oxford_bloke
in which case i would scrap the body lift for the moment as all that does is give you clearance between the chassis and the body to make way for larger tyres. so for a 2 inch lift the ideal situation would be to get the whole sherbang ( new springs,shocks, radius arms, panhard rods) but for this you are looking at about £1000+
However it can be done a lot cheaper by using spring spacers and shock extenders then all you would need to do is extend your brake lines and get some caster correction bushes to stop the jimny death wobble. i would also recommend if you do this to get new springs as depending on the age of your jimny the springs could have sagged a large amount.
hope this helps
hope this helps
- Skinhead
- Visitor
03 Mar 2012 16:43 #34734
by Skinhead
Well i certainly havnt got a £1000 to spend on it, ill stick with the second option! An as for the bodylift, im only really getting it for the look, i like the high look. Im hoping to get the bodylift kit abit cheaper and a mate is going to help me fit it. I think i will leave the castor correctors for now an maybe get them on when i have abit more money. My jimny is a 2000 with 96k miles. Thanks mate
- sully
- Visitor
03 Mar 2012 16:45 #34735
by sully
Replied by sully on topic Re: I need help with lifting my jimny!
i got 2nd hand springs and shockers(3") just gave them a lick of paint and put new bushes in and they work fine you just need to keep an eye out
- oxford_bloke
- Visitor
03 Mar 2012 16:52 #34736
by oxford_bloke
no worries a body lift is dead easy. if you want the look you need to fill out the arches a bit so maybe consider some bigger rubber. as an idea i have a 4.5 suspension and +2 body lifts and 235/85/16s (32.5ish) look just right
- Skinhead
- Visitor
03 Mar 2012 16:59 #34737
by Skinhead
Yes i keep checking ebay for second hand lift springs, do you know where else i can look?
Cheers
Cheers
- sully
- Visitor
03 Mar 2012 17:28 #34739
by sully
i got mine off here was lucky i think but there was a set for sale a couple of weeks back still mite be up for sale think there called suzuki jimny fella (3" lift )or try ypvs jimny 350 (2" lift) hope this helps good luck
- supergaz
- Visitor
03 Mar 2012 18:53 #34746
by supergaz
Replied by supergaz on topic Re: I need help with lifting my jimny!
A body lift is fairly simple, the only problem is to slightly bend the transfer box lever slightly forwards. Now i've done mine, I could easily do one in less than an hour.
You wont need a prop spacer, only if you are using castor correction arms for more than a 3" lift.
With a 2" lift id recommend castor correction bushes.
As for the age and mileage on your jimny id change the springs as the original springs will have sagged easily by a couple of inches.
Get some rear shock brackets as your shock bushes wont last long without these.
Time to create page: 0.198 seconds
