stupid question
- adam
28 Feb 2012 14:04 #34400
by adam
Hello ladies and gents!
Iv got a quick question. Has anyone had problems applying a vinyl front number plate?
I fitted one a while back and it creased and it took 2 hours to remove and left some nice scratches!
I have now just bought a new one to have an other attempt.
should a dampen it or the bonet first or do I just have to be super careful?
Iv blacked my windows out and applied graphics before but never had this problem!! :blink:
ps I know I dont need a vinyl one but personally I like the look!
stupid question was created by adam
- adamjimny
28 Feb 2012 14:38 #34402
by adamjimny
Replied by adamjimny on topic Re: stupid question
Use some soapy water on surface which allows it to slide to position it correctly then leave it to dry.....be sure to get all air bubbles out.
I do this with all decals
Sent from my GT-I9100 using Tapatalk
- adam
28 Feb 2012 14:55 #34405
by adam
Replied by adam on topic Re: stupid question
Right, you see I wasnt sure if I could do that with the plate, dont know why :side: !! Thanks
- adamjimny
28 Feb 2012 15:17 #34406
by adamjimny
It will still have the same sticking propertys and works for all self adhesive surfaces iv done it on
- trextr7monkey
28 Feb 2012 16:53 #34417
by trextr7monkey
Replied by trextr7monkey on topic Re: stupid question
Most of our stuff we apply dry - needs 2 sets of hands though, -keep it all under slight tension and press down firmly as you go, from centre outwards.
To remove warm gently with a hair dryer and it should peel away perfectly.
atb
Mike
atb
Mike
- myers647
28 Feb 2012 18:08 #34424
by myers647
Replied by myers647 on topic Re: stupid question
Hi mate,
Iv done my own tints and decals on my cars in the past and also put my vinyl number plate on the bonnet. Use some soapy water and then if its not quite straight you can move it about untill you are happy then either just leave it to dry or use a bank card or squegey to push the water out and it will stick straight away.
Put the vinyl plate on the flat of the bonnet not on the rounded part as it will crease.
Thanks
James
Thanks
James
Time to create page: 0.095 seconds
