Standard Jack Handle.
  • darthloachie
22 Feb 2012 12:33 #34013 by darthloachie
Replied by darthloachie on topic Re: Standard Jack Handle.
Johnniehec wrote: Unfortunately my jack was missing, presume lost in action , when I bought my Jimny, so I don't know what it even looks like. I carry a landr***r bottle jack out of a 1990 RR vogue SE I scrapped (the jack was the only bit worth keeping, rust had got the rest of it). Only downside is it tends to disapear into the ground rather than lift the Jimny off road, yes I know I need to carry a piece of wood! I have a trolley jack in the garage.
john.
one of these would do the job
22 Feb 2012 16:04 #34020 by facade
Replied by facade on topic Re: Standard Jack Handle.
How do they work?
Seems mostly holes to me, you want a solid board to give a large surface area.
Are you supposed to wrap them with something?
Or do they just sink in and keep the jack level?
I have a RangeRover jack too. They are perfect, have a curved top to locate under the axle tube and a 2 stage lifting ram so they go down small enough for a flat tyre and go up high enough to get an inflated one on.
22 Feb 2012 16:16 #34023 by mcjimny
Replied by mcjimny on topic Re: Standard Jack Handle.
I've never used my jack either but all cars have the same problem. Its a flaw of a scissor jack, when its low you drag your knuckles on the ground trying to get enough pull on it and then when its higher its too close to the car! I can't see why they didn't design it with a ratchet of some sort. Anyway they're just an emergency tool i've got a trolley jack for use at home but will be getting a pair of bottle jacks shortly.
I can't see those waffles working either, the proper hi-lift ones are solid i thought and attach to the jack?
  • darthloachie
23 Feb 2012 07:32 - 23 Feb 2012 07:34 #34059 by darthloachie
facade wrote: How do they work?
They only sink into the gound if its very muddy otherwise they spread the load of the jack over a greater surface area the hi lift stand is great but over £45 and would still sink into mud
we have a pair of 4 ft long ones we use under the wheels if stuck in gloop and too far away from a tree to winch
Last edit: 23 Feb 2012 07:34 by darthloachie.
23 Feb 2012 08:40 #34063 by andyw
Replied by andyw on topic Re: Standard Jack Handle.
Wandering star,
Where are you putting the scissor jack, If your using on the arms it should be long enough, the arms have a small round disc on the casting that the hole in the top plate of the jack mates to. It's not ment to go under axle If your using it there mate.
Andy
  • wanderinstar
23 Feb 2012 12:09 #34072 by wanderinstar
Replied by wanderinstar on topic Re: Standard Jack Handle.
Hi Andy,
I tried under the sills when I first got it. Then when I obtained a handbook. I realised that I was supposed to jack up using the "pips" on the suspension arms. Thanks anyway.
Time to create page: 0.150 seconds
