will it ever be finished !
- viciouspenguin
- Visitor
and if its not having new toys bolted to it then I'm probably fixing old bits... :silly:
- darthloachie
- Visitor
defender arches
land anchor
driving lamps
beadlocks
more power
more height
bigger tyres
etc etc
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
I made all the expensive mistakes on my first Jimny which was never finished.
I fill it up with fuel before I go laning, and wash it when i come back, thats it, just enjoyment now.
Gary
- supergaz
- Visitor
- Mumbo Jimbo
- Visitor
- viciouspenguin
- Visitor
MysticRich wrote: Know what you mean about the spare wheel I,ve 32" tyres on and carnt use rear view mirror carnt see nothing but tyre out of rear window . do any of you with rocklobsters fitted get vibration in the transfer tunnel still. Just fitted mine using o.r.a kit and had props made and all balanced but still get vibration I,m thinking its due to the transfer mounts ? Any idea,s
check the UJs, the smallest bit of movement can cause vibrations.
- stevedumptruck63
- Visitor
- stevedumptruck63
- Visitor
- r_ogilvy
- Visitor
stevedumptruck63 wrote: yeah,one of those 12ton bottle jack types does up to 2" pipe,should be up to the job.
yeah it will do the job, i use one. i would recommend filling the pipes with sand and pack the formers for a tight fit, then they will bend a 90 degree bend nice. if you havn't used one before
- stevedumptruck63
- Visitor
- r_ogilvy
- Visitor
stevedumptruck63 wrote: cheers thanks for the advise,i think i will do a bit of practice work first.
when you get use to it, its great what you can make up with it
- stevedumptruck63
- Visitor
